Regarding Code of Channels
Forum Home › Forums › Understanding the Software › Regarding Code of Channels
  • #14754
    zzz
    Hi, Mikhal,
    What is the use of the Code col. in Channel table. It doesn’t seem to have been used anywhere. Is there any constraint for it ? Does it require values to be unique, though currently it seems that there is no rules imposed on it.
    I am storing values in this col, just want to make sure it’ll not cause issue in future versions.
    Regards,
    • This topic was modified 2 years, 4 months ago by zzz.
    #14756
    If I’m not mistaken, by specifying Code, you can send commands by Code and not by channel number.
    #14765
    The Code column is used for integration with other systems. You can enter any text into it.
    The Tag Code column is important for Communicator.
    #14769
    zzz
    Hi guys, Thank you for making it clear.
