OPCUA Remote Configuration Issue
Forum Home › Forums › Development and Integration › OPCUA Remote Configuration Issue
  • #14573
    zzz
    In cases where
    1. In a development environment where the IP Port or Subnet settings differ from production environment, but OPC setting are identical.
    2. When the Communicator, Remote OPC UA server and Admin app are on different boxes and different networks, have different accessibility to each other.
    I think it helpful to provide a Test Server URL textbox on Admin App’s OPC UA Properties window. allowing the user to
    set the address for Communicator in original Server URL textbox as usual,
    in the meanwhile pulling nodes from the Test Server URL server for configuration, without uploading this Test Server URL to Communicator.
    I never felt such is necessary for Modbus. The difference lies in the fact that the OPC properties window is a preview and click based process, which requires connection. I don’t mean this is a drawback, but makes an independent Test URL valuable when connectivity differs.
    #14581
    The other possible approach we use in DrvOpcClassic.
    A user can download the structure of the OPC tags to an XML file using a utility. Then open that XML file by a driver UI instead of connecting to an OPC server. May be this approach is straightforward and easy for understanding.
    For example, a customer can send you an XML file containing OPC nodes. Then an engineer can use it in his office.
    #14584
    zzz
    In my case I am not worried by the offline issue, since without connection to the RS instance, SA also can’t connect, to me there’s nothing to config. If I am offered connectivity to the remote RS box, I can port forward the remote OPC UA addr+port to a local port for SA to connect through the RS box, it’s just the address will not be the same.
    In the case of running a dotnet tool on an existing OPC servers, if that box has restrictions, quirky settings or very old OS, things might not necessarily go easier.
