Forum Home › Forums › Development and Integration › New Scheduler Module V6.0.0.0
- This topic has 11 replies, 2 voices, and was last updated 1 year, 9 months ago by
CCKOH.
December 14, 2024 at 5:58 am #15771
CCKOH
ParticipantHi All,
Iām pleased to publish a Scheduler module use to send the Command on the Scheduled Date Time.
This module tested on both Windows and Linux Machine.
Module documentation Link:
https://drive.google.com/drive/folders/1HPhiHKVdlsRkl0UWw4BBwecp3EawtXY0?usp=drive_link
This is a paid module. The cost is $88 for Personal and $168 for Business.
Kindly fill in the Google form https://docs.google.com/forms/d/e/1FAIpQLSdagqISf4b96Pp1MW0tT9I92_RN3p-G-uRzmvJVlBYKLNjLAg/viewform?usp=sf_link
or write email to me @ cckoh0528@gmail.com to obtain 7 days free trial Activation Code.
Please do not hesitate to contact me or post in this forum if you encounter any problems on implementation of this modules.
Thank you.December 14, 2024 at 11:08 am #15773
manjey73ParticipantPlease make the documentation available to the public
December 14, 2024 at 4:15 pm #15774CCKOH
I’m just change the access control setting. Please help check if still got issue of viewing and downloading the distribution package.Thank you.
Regards,
CC KohDecember 14, 2024 at 5:14 pm #15775
manjey73ParticipantOK, I downloaded it. But I don’t promise to try it out quickly. I’ve read the readme, but I’m still wondering if I need it. The auto-control module seems to allow you to do the same thing. Although the ability to make settings from the web is super. But according to the description, I still understood that it is necessary to use the Administrator application.
December 15, 2024 at 6:00 am #15776CCKOH
Thank for downloaded the module. Hope you can try it.The Scheduler use the Administrator application to upload the configuration to the Server only. After done, every Schedule setting is done on Web pages.
The module is useful if the Schedule need to change periodically or on ad-hoc basis (for example extended On hours for Air Cond) while there is not necessary open the Administrator app to upload to the Server especially when off site and the Administrator app not reachable.
It is also user friendly for public (or so called layman) who do not have experience on programming Rapid Scada.
December 16, 2024 at 1:23 pm #15785
manjey73ParticipantThere are a lot of questions at once š
December 16, 2024 at 2:22 pm #15792
manjey73ParticipantIt is incorrect to use the same tag code for multiple channels on the same device. This contradicts the concept of Scada.
The same tag codes are allowed on different devices.December 16, 2024 at 4:34 pm #15803CCKOH
ParticipantHi Manjey,
Reply for the Big Screen 1:
1) The plgScheduler will automatically pick up the Channel and display on the Select Channel drop down list if you specify “Scheduler” on the Tag Code inside configuration table.
2) Frequency will base on the Schedule Date Time specified.
for example: if your specified Date Time: 17/12/2024 12:20AM,
Frequency – One time: the command will send on 17/12/2024 12:20AM
Frequency – Weekly: the command will send on 17/12/2024 12:20AM and rescheduled on 24/12/2024 12:20AM and so on
Frequency – Monthly: the command will send on 17/12/2024 12:20AM and rescheduled on 17/01/2025 12:20AM and so on
3) Currently, there is not Device display on the Scheduled Commands Table. Will take note and revise on the next revision.
4) Only Action Delete is available. Changing of scheduler time can be done by Delete it and create a New one.Noted on the comment tag code shall not use as the identifier for Scheduler. However, The Scheduler can still be used by manually Enter Channel Number.
Shall we use “Code” as the identifier for Scheduler?
Regards,
CC KohDecember 16, 2024 at 4:46 pm #15807
manjey73ParticipantIt is better not to use the tag code to identify the scheduler. I added two channels, and only one of them was displayed in the table. I think the best option would be to make a choice from the list of channels, like it is organized in ChartPro, but even there it is not the best option. Calculating Fridays or Saturdays from the specified date and time is also not the best option. If the scheduler can work with any channels, then why should it identify itself? but editing tasks created by the scheduler would be very useful. There is also a question, commands can also be string, string HEX, string Date. can he send commands like that?
December 16, 2024 at 5:40 pm #15809CCKOH
reply: I’m tested on the Hello World project, if both channels Tag Code label as “Scheduler”, both channels was display. refer screenshot https://drive.google.com/file/d/1SY3skA1vljN_SJAW7yuxdBku2ixmuCih/view?usp=drive_link>>I think the best option would be to make a choice from the list of channels, like it is organized in ChartPro,
reply: In my opinion, it will become very messy if there is 100 of output channels and all un-relevant channel is display. That is why the “Scheduler” identifier is introduced to only display the relevant output channel which need Scheduler function.>>Calculating Fridays or Saturdays from the specified date and time is also not the best option.
reply: There is not calculation from the user is needed. The re-scheduled date time is automatically display on the Scheduled Command Table when you refresh the pages after the current command is executed.>>commands can also be string, string HEX, string Date. can he send commands like that?
reply: currently not support. can be added in the next revision if it is commonly needed.Regards,
CC KohDecember 16, 2024 at 8:25 pm #15814
manjey73ParticipantI’m talking about the presentation table, two channels with the same tag code name are not displayed
there šAnd there is no need to talk about the channel, which is an output channel and has its own unique tag code.
January 9, 2025 at 6:30 am #15953CCKOH
ParticipantHi All,
I’m pleased to inform new update version of Scheduler Module Ver 6.1.0.0The update as following:
1) Remove the use of ‘tag code’ as identifier for Scheduler.
2) Add in Select Device dropdown menu. List of Associates Output Channel will be display base on selected Device.
3) Add in Send Command Data function.
4) Add in Device name column on the Schedule Command list.The new activation code for V6.1.0.0 have been send out to all the module purchaser. For the trial user, kindly obtain new activation code from me.
Regards,
CC Koh -
