MQTT connection boost
Forum Home › Forums › Communicating with Devices › MQTT connection boost
  • #6700
    Roland
    I have a question about the mqtt communication. I am using mosquitto broker and have set up a publisher to send 100 messages without any delay inbetween. Once the sending finishes, rapid scada still receives incoming data. I think, it receives approximately 10 values from the publisher in every second. Is it possible to boost this up somehow? Is it possible to achieve ~100 or more mqtt message receiving in every second?
    Thanks.
    Roland
    #6710
    Try decreasing the delay parameter for the device in Communicator.
    It’s here http://rapidscada.net/doc/content/latest/en/software-configuration/communication-with-devices-files/comm_line_req_en.png
    This should increase polling rate.
    #6711
    I’m not sure, but may be MQTT is not very fast communication protocol. To compare, try the Modbus example and measure how many messages you can receive per second.
    #6712
    Also, set all data and log folders in C:\SCADA folder as exception for anti virus system, because it checks every file after every change.
    #6713
    And you should write the results after changing something in the system to understand which approaches work.
