How to print the current configuration for the project documentation
Forum Home Forums Uncategorized Issues How to print the current configuration for the project documentation
  • #6836
    tom040264
    Hi guys,
    I use two versions of Rapid SCADA, 5.6 and 5.8. Is it possible to print out the whole configuration for the project documentation, it means all definitions from the Administrator and from the Communicator? Of course I can improvise by using the screen shots, or to print the XML-files, but it would be nice to have a direct way to create this print out.
    Thank you
    Regards
    T.
    #6839
    In Rapid SCADA 5.8 you can export tables of the configuration database in CSV format and then print them by Excel.
    Configurations of the other applications are stored in XML files. You could open them in Notepad++ and print.
