How to connect a Profinet device? Forum Home › Forums › Communicating with Devices › How to connect a Profinet device? This topic has 3 replies, 2 voices, and was last updated 3 years, 11 months ago by Mikhail. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts November 28, 2022 at 9:22 am #11692 dylanyeo22Participant Good day all, I am trying to connect a profinet master to Rapid Scada but I am stucked. I’ve saw a 2016 post that a plugin can be used or go through OPC. However, I am unable to find a Profinet plugin to Rapid Scada and the guides to configure OPC is slightly outdated as well. I would like to ask if anyone in the community knows the most suitable way forward? Thank you all November 29, 2022 at 9:56 am #11695 MikhailModerator Hello, May be you can try this OPC server https://www.matrikonopc.com/drivers/opc-siemens.aspx to integrate Profinet and Rapid SCADA. November 30, 2022 at 3:04 am #11698 dylanyeo22Participant Hi, thank you for the response. I shall look into the server mentioned above. Profinet is a restricted protocol and I hope to get some breakthrough soon November 30, 2022 at 8:51 am #11701 MikhailModerator Hi, Please write about results. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
