Hello sir
I have got a data 96 from postgresql and created a input channel 1001.
Can i automaticlly send 96 to PLC ?
Does rapidscada have such a function?
what can i do?
Thank you sir.
This topic was modified 9 years, 4 months ago by Mikhail.
1.Generate a file that name is KpPost.dll .The file depends on a Npgsql.dll
2.Use the SetCurData method to set the current value.
3.KpTestView class inherits the KpView class and then creat input channels.
If you create a module for SCADA-Server, you can use PassCommand() method within the module.
If you create a driver for Communicator, you can use CommLineSvc.PassCmd() method to send command to a device that is bound to the same communication line.
I mean that a command sender device and a receiver device must me within the same communication line in the Communicator settings. Otherwise it’s better to create server module DLL than a driver.
