ERROR
  • #16949
    Hcinarli
    I am trying to install on my Windows 7 64-bit operating system, but I am getting an error. The log file is below. What can I do? Thank you.
    Rapid SCADA 6.4.2 Installation
    Windows is outdated. The installed applications may not work correctly.
    Check TCP port 10000
    TCP port 10000 is available.
    Check TCP port 10002
    TCP port 10002 is available.
    Check TCP port 10001
    TCP port 10001 is available.
    Check TCP port 10008
    TCP port 10008 is available.
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\Common.zip
    Install Server application
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaServer.zip
    Install ScadaServer6 service
    Installation of Server application has completed successfully
    Install Communicator application
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaComm.zip
    Install ScadaComm6 service
    Installation of Communicator application has completed successfully
    Install Webstation application
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaWeb.zip
    Installation of Webstation application has completed successfully
    Create website
    Geçersiz dizin. (0x80070585)
    Install Agent application
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaAgent.zip
    Install ScadaAgent6 service
    Installation of Agent application has completed successfully
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaAdmin.zip
    Create Administrator shortcut
    Register file association “.rsproj”
    Installation of Administrator application has completed successfully
    Install Scheme Editor application
    Unzip files from C:\Users\bilgisayar\Downloads\rapidscada_6.4.2_windows_en\Zip\ScadaSchemeEditor.zip
    Installation of Scheme Editor application has completed successfully
    Write product name and version
    Start service ScadaServer6
    Start service ScadaComm6
    Start service ScadaAgent6
    Installation has completed with errors
    #16950
    I assume that the problem is either in dotnet or in the settings of additional Windows components.
    The installer doesn’t seem to install dotnet on its own
    • This reply was modified 1 year, 1 month ago by manjey73.
    #16952
    Make sure that IIS is installed and works correctly.
    #16953
    Windows 7 is not supported. Minimum is Windows 10.
