Difference b/w OnCurDataProcessed and OnCurDataCalculated
Forum Home Forums Understanding the Software Difference b/w OnCurDataProcessed and OnCurDataCalculated
  • #8638
    zzz
    Hi Mik,
    Could you elaberate on the Difference between OnCurDataProcessing[1]/ed[2] and OnCurDataCalculating[3]/ed[4] ? They seem to be invoked by different threads. What is their difference in use?
    #8639
    OnCurDataProcessing – when new data are coming from a controller.
    OnCurDataCalculating – when input channels of the calculated type are calculated.
    “ing” – before
    “ed” – after
    #8683
    zzz
    Hi Mik,
    Thanks for info, so if I got you correctly the process is :
    OnCurDataProcessing       Real/Discret only
    v
    Formula process           Real/Discret only
    v
    OnCurDataProcessed        Real/Discret only
    v
    OnCurDataCalculating      Calculate only
    v
    Formula process           Calculate only
    v
    OnCurDataCalculated       Calculate only
    instead of what I was confused like
    v
    v
    OnCurDataCalculating      Real/Discret/Calculate
    v
    OnCurDataCalculated       Real/Discret/Calculate
    #8699
    I would insert logging in the module you working on, and see the actual sequence.
    Server calculates formulas for “calculated” channels in the main thread, while data from Communicator are coming from another thread.
    • This reply was modified 5 years, 5 months ago by Mikhail.
