Device Connection Sequencing
Forum Home › Forums › Communicating with Devices › Device Connection Sequencing
  • #15748
    r1moore
    Is there a way to adjust how persistent the device connection is with the Rapid Scada Communicator? I am looking for a way to connect to a device only for requesting data and sending commands and then disconnect so that the SCADA server does not continuously occupy the port.
    #15751
    JW
    Assuming you are using scada as TCP client type, goto the following settting,
    Communication Lines – Line Options – Main Options – Properties, uncheck the “stay connected” option
    And don’t forget to set the interval “Delay after pooling cycle”
