Default properties for newly created channels
Forum Home › Forums › Understanding the Software › Default properties for newly created channels
  • #18138
    Andi
    Hello Mikhail,
    I am currently building a larger Rapid SCADA project with several hundred channels.
    Many channels require the same configuration, for example:
    – Input Formula (CnlVal/10)
    – Display format
    – Physical quantity and engineering unit
    – Archive settings
    – Event settings
    At the moment I have to configure these properties manually for every new channel.
    Is there a recommended way to define default properties or channel templates, so that newly created channels automatically receive these settings?
    I am trying to establish a consistent project structure before creating a large number of channels.
    Thank you very much for your advice!
    #18139
    WayneS
    Greetings from New Zealand,
    I have found the easiest way to do this is to use the Tools/project tools/export table to export your channels to a spreadsheet (.csv). You have then copy the channel(s), change the channel numbers. Once finished save the spreadsheet as a .csv then use the import table to add the new channels. I did this for three large identical devices – make the first one with channel numbers 1000-1999, then copy and nake second one 2000-2999, thord one 3000-3999.
    regards Wayne
    #18140
    if the devices are the same, one is configured, then cloning with an indication of the device change. But if the devices are different, then we have sailed to manual labor 🙂
    #18145
    As a recap, possible solutions are
    1. Cloning channels.
    2. Export to CSV, edit in Excel, import from CSV.
    3. Edit a table directly in XML.
    4. Copy/paste cells by Ctrl+C and Ctrl+V.
