i need to set value giving command on a group of device OPC UA, when push button:
Button ON – send value 1 to command 1 to device (211,212,213 )
Button OFF – send value 0 to the same group
i have channel 30010 connected to button OFF and channel 30011 connected to button ON
OUTPUT CHANNEL
30010 -> SetVal(20011,0)
30011 -> SetVal(20011,1)
in this way the buttons change value of input 20011 (Calculated Discrete)
With Automatic Control Module i can trigger the input and send the commands to devices.
The problem is that if i push 2 times button ON, the 2th time the action is not executed, seem that “channel data trigger” trigger only when the value change.
Is there something wrong?
This topic was modified 3 years, 10 months ago by
