Auto report module errors
Forum Home Forums Understanding the Software Auto report module errors
  • #16636
    kcks66
    Hi Mikhail,
    I am testing the auto report function together with elastic report and email. I wish to auto sending out elastic report by email in a daily schedule.
    So far I managed to configure elastic report and email service. I can download elastic report from Rapid SCADA web and send email manually.
    I configured the auto report module following v6 documentation. I managed to get the auto report module to forward reports (Historical Report and Elastic Report) to my email address.
    However, I got two errors. First error is there is message pop up mentioned workbook setting problem when I open the file with excel. The second error is from log.
    Error 1:
    https://ibb.co/fdz3C8wn
    Error 2:
    https://ibb.co/NnsMgF69
    My report 1 config:
    https://ibb.co/gbHQZ4vv
    My report 2 config:
    https://ibb.co/FLKjjpmk
    Pls advice for my mistakes. Thank you.
    #16638
    1. Could you make a screenshot of the report when you download the same report from a web page?
    2. What result do you get if you choose the HTML format in the Auto Report settings?
    3. Try using en-GB culture if you use another culture.
    #16657
    kcks66
    Hi Mikhail,
    After I change culture to en-GB, no errors at log and excel file (Historical Data Report & Elastic Report) when I opened them.
    https://ibb.co/GQKLXfRF
    Everything look fine except Auto Report Module automatically export the Event Report even I didn’t activate it.
    https://ibb.co/QjCCRdnD
    #16671
    The PlgElasticReport.zh-Hans.xml file includes a line
    <Phrase key="WorksheetName">工作表{0}</Phrase>
    Likely there is some forbidden character.
    Try replacing that line by the similar line from PlgElasticReport.en-GB.xml
    • This reply was modified 1 year, 1 month ago by Mikhail.
    #16673
    Restart the service after changing the configuration.
    #16674
    It’s a bug. Will be fixed in the next version.
    #16677
    kcks66
    Hi Mikhail,
    Noted.
    #16679
    Thank you for noticing the bug.
