Assign CodeSys OPC and Rapid SCADA
Forum Home › Forums › Communicating with Devices › OPC › Assign CodeSys OPC and Rapid SCADA
  • #638
    Evgen
    There PLC 100 is programmed in the medium codesys you want to display data from it in slow motion scada and subsequently through lokalhost send them over the network through a browser
    The question is how you next entries, kodesis opc with Rapid SCADA?
    #639
    If you’ve got an OPC server for your PLC, you can retrieve data with help of Rapid SCADA. Probably you can configure Modbus using CoDeSys and establish a connection via Modbus. Useful articles:
    http://rapidscada.org/connecting-devices-using-opc-standard/
    http://rapidscada.org/connecting-devices-using-modbus-protocol/
    #640
    Evgen
    The fact of the matter that I did all of the instructions with these links.and I saw the article in the forum as people turned out, and I have all the screenshots as well. but does not work
    #641
    Evgen
    I have not lit display communication with the controller. as if he did not interrogate !!!
    I think this is the case, how to overcome?
    #642
    Please provide more information about the actions you have done.
