Rapid SCADA 6 Beta
Forum Home › Forums › Uncategorized Issues › Rapid SCADA 6 Beta
Viewing 7 posts - 76 through 82 (of 82 total)
  • #11850
    geffzhang
    Does Storage have any plans to support MS SQL Server?
    #11853
    There is a DB Export module that can write data to MSSQL.
    We don’t have a plan to develop MSSQL archive (similar to ModArcPostgreSql, for example). It can be done by other developers, or we can implement MSSQL archive by a contract.
    #12934
    JW
    Since now the ModArcPostgreSql are available, is there any planning on making configuration Database “BaseDAT” also stored in PSQL?
    Then the users can change their passwords, admins can edit alarm threshold on the web .
    #12946
    Currently it is possible to upload the project to PostgreSQL https://ibb.co/TLdT8Zt
    But project changes are stored as usual in XML files and later uploaded to the database. It would be interesting in the future to implement an alternative approach, edit project directly in the database. It would require fully new, web based Administrator app.
    #12947
    You can find in ScadaInstanceConfig.xml the option to change file storage to PostgreSQL storage. If the PostgreSQL storage is selected, the Server app loads a project from the database.
    #12953
    JW
    Fully editable for all Configuration Database maybe not necessary. Partially editable maybe even better for admin to control the access of users.
    e.g.
    In the table view, the displayed channel can be check and edit for the alarm limits.
    But does it require restart of the scadaserver service to be effective after changing alarm limit settings if configuration stored in DB?
    #12955
    Currently, yes. We need a special command to reload users and limits to avoid restart.
    Limits are checked many times a second, so we can’t read them from the database every time, and should keep them in the memory cache.
