Windows Scada project upload in Ubutu
Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Windows Scada project upload in Ubutu
Viewing 9 posts - 16 through 24 (of 24 total)
  • #15322
    /var/log/scada/ScadaAgent/Log
    Directly on the Linux machine along the logging installation path
    • This reply was modified 2 years, 2 months ago by manjey73.
    #15328
    rajatdas2005
    user@rajat:/var/log/scada/ScadaAgent/Log$ cat ScadaAgent.log
    2024-09-09 06:03:37 [rajat][root][ACT] Agent 6.2.0.1 started
    2024-09-09 06:03:37 [rajat][root][ACT] Start logic processing
    2024-09-09 06:03:37 [rajat][root][ACT] Start listener on port 10002
    #15330
    The Agent’s log shows which port it is listening on.
    1. check that this port is not occupied by other programs
    2. Check the firewall to make sure that the port is open.
    Ubuntu may have another firewall installed – UFW, or disable it for verification, or configure it to skip port 10002. On one remote VDS server, even with uwf mode configured, it periodically closes until I figured out how to win.
    #15331
    netstat -ntulp
    or
    ss -ntulp
    What does the command data show on the remote server? These are commands for ssh connection
    #15332
    rajatdas2005
    ss -ntulp
    Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
    tcp LISTEN 0 512 0.0.0.0:10008 0.0.0.0:*
    tcp LISTEN 0 10 0.0.0.0:10003 0.0.0.0:*
    tcp LISTEN 0 4096 0.0.0.0:10002 0.0.0.0:*
    tcp LISTEN 0 4096 0.0.0.0:10000 0.0.0.0:*
    tcp LISTEN 0 10 0.0.0.0:10006 0.0.0.0:*
    tcp LISTEN 0 10 0.0.0.0:10005 0.0.0.0:*
    tcp LISTEN 0 10 0.0.0.0:10004 0.0.0.0:*
    #15334
    You can use the Hercules Utility to check connection from Windows to Linux. Use the Linux IP address and TCP port 10002.
    #15335
    You have a lot of ports on 1000x 🙂 What do you have installed there?
    Check if UWF is installed and enabled? and if it is enabled, are these ports open in it?
    I’m sorry, it’s called ufw correctly
    ufw status
    #15339
    You should get the open ports in ufw in the list
    10000/tcp                  ALLOW       Anywhere
    10002/tcp                  ALLOW       Anywhere
    10008/tcp                  ALLOW       Anywhere
    10008                      ALLOW       Anywhere
    #15360
    rajatdas2005
    Now the port is opened, and I am able to deploy the project in the remote linux machine. Thanks a lot for help.
