Utility Pack 6.0 Instructions
Forum Home › Forums › Understanding the Software › Utility Pack 6.0 Instructions
Viewing 3 posts - 16 through 18 (of 18 total)
  • #15856
    fischerp
    I am also interested in the possibility of creating a pure CSV file without an XML header.
    Could you provide an example of the existing file you get and a file you need?
    This is just what i need.
    I also found ExtExternalTools and tried to use it.
    I created a new entry (add), gave it a name (Create CSV), and specified the location of the exe file. Arguments = {ItemFileName}, which is probably the channel name. Working directory is the storage location of the EXE file.
    The whole thing is saved and uploaded.
    Now it should be possible to create an entry in the project tree somewhere, e.g. in Views.
    This is how the mask for ExtExternalTools is filled in
    https://imgur.com/a/DXsXmlT
    Presumably I still have to enter this in Views? But how?
    https://imgur.com/a/Q7LXkuR
    #15857
    fischerp
    vermutlich habe ich mich unkla ausgedrückt, die Art, wie die Datei erzeugt wird, ist genau das, was ich benötige. Was mir fehlt, ist die Einbindung in das UI.
    Ich fülle die Eingabemaske für ExtExternalTools so aus:
    ExternalTools
    Where do I have to enter the program call so that it can be called by the UI? In views? How?
    Views
    #15864
    If you need to execute some external app from the web interface, there should be another approach. Please create a new topic to discuss it.
