Unable to send command from toggle via web interface
Forum Home › Forums › Communicating with Devices › Unable to send command from toggle via web interface
Viewing 16 post (of 16 total)
  • #8225
    dinop
    I don’t know if it’s the right place to post a question but here it is.
    I want to know if is possible to send command from Rapid Scada to PLC.
    I created a screen with Scheme editor and I want to create a button that will be an input for PLC (for example: a button which starts a sequence)
    Is that possible and how?
    I created a BOOL inside TIA Portal. Now what? How to declare it in Rapid scada to perform a task such as, start sequence.
    Communication used is OPA UA.
