SMS with two factor authentification
Forum Home › Forums › Understanding the Software › SMS with two factor authentification
Viewing 4 posts - 16 through 19 (of 19 total)
  • #17376
    oley
    Hi Mikhail,
    I was able to get it working with ACM and the phone book – I just need to use the Notif command.
    Unfortunately, if I have Channel DataChange Trigger in ACM, it fires after every configuration upload.
    #17377
    oley
    Another approach that scales even better: EventTrigger.
    I just set the channel and nothing else.
    I connect the copied Notif command to the DrvHttpNotif device.
    After changing the channel, an event appears, and in the ACM log I see:
    2025-12-04 21:57:45 Send command. Device 200, command Notif
    Unfortunately, nothing happens, silence in the DrvHttpNotif device log.
    Any idea?
    #17379
    Let’s discuss ACM triggers in a new topic. I suppose, it’s possible to find the appropriate type of trigger.
    #17380
    As a recap:
    – You can send notifications with custom text using the phone book,
    – You need to configure commands sent by ACM
