SMS GSM Cinterion Modem
Forum Home › Forums › Understanding the Software › SMS GSM Cinterion Modem
Viewing 10 posts - 16 through 25 (of 25 total)
  • #11948
    hethongscada62
    Dear Mr.Mikhail,
    Yes I was tried to send. You can see screenshot bellow:
    https://ibb.co/Fs7kSFH
    https://ibb.co/PgLKb0r
    SMS can not send.
    Where is wrong?
    Thanks a lot
    Han Hoang
    #11957
    Dear Han,
    Something wrong in SMS packet. To find a cause, it’s needed to learn SIM808 documentation and make a research. Such work is not included in support.
    I recommend to use Telegram to send notifications. Or use special REST web services.
    #11958
    May be you should try to find utilities that send AT commands to modem and test them.
    #11962
    hethongscada62
    Dear Mr.Mikhail.
    Thank You for your repply. Maybe I will use another modem.
    Thank you again.
    Han Hoang
    #11969
    Modem should be Siemens C35 compatible.
    For example, we successfully used Huawei E1750
    #11997
    hethongscada62
    Dear Mr.Mikhail.
    Modem Siemens C35 is difficult to get it in my country. Huawei likes E173x is popular. Dcom USB 3g Huawei is connecting to test. Using this modem to send SMS on computer it works perfectly. Testing to send SMS via Rapid Scada It not worked. Fault is the same.
    https://ibb.co/xJwrKgr
    https://ibb.co/LvpKqqH
    Where is wrong?
    Thank You again.
    Han Hoang
    #12000
    According to the log, the modem does not respond: Receive: no data
    You could compare with the previous logs.
    Check connection settings.
    • This reply was modified 3 years, 10 months ago by Mikhail.
    #12035
    The SMS driver has been ported to v6. It is tested with Huawei e1750.
    Successful data communication is in the screenshot https://ibb.co/MkdbhqG
    #12049
    hethongscada62
    Dear Mr. Mikhail,
    My project is running on Webstation V5.1.0.0. Did you test a Huawei e1750 with V5.1.0.0?
    Thanks and best regards
    Han Hoang
    #12050
    Dear Han,
    KpSms.dll of any version supports Huawei e1750
