Forum Home › Forums › Runtime Bugs › Server problem
- This topic has 22 replies, 2 voices, and was last updated 6 years ago by
October 12, 2020 at 3:07 pm #7421
Marko
ParticipantHello,
i manage to get information from communicator log when server stop.
2020-10-12 16:36:31 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=62, number=4
2020-10-12 16:37:11 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=61, number=4
2020-10-12 16:37:31 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=62, number=4
2020-10-12 16:38:11 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=61, number=4
2020-10-12 16:38:31 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=62, number=4
2020-10-12 16:39:11 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=61, number=4
2020-10-12 16:39:31 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=62, number=4
2020-10-12 16:40:11 <VMI398773><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=61, number=4
2020-10-12 16:40:42 <VMI398773><SYSTEM><EXC> Error sending current data to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2020-10-12 16:40:42 <VMI398773><SYSTEM><ACT> Disconnect from SCADA-Server
2020-10-12 16:40:42 <VMI398773><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2020-10-12 16:40:47 <VMI398773><SYSTEM><EXC> Error connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2020-10-12 16:40:47 <VMI398773><SYSTEM><ACT> Disconnect from SCADA-Server
2020-10-12 16:40:47 <VMI398773><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2020-10-12 16:40:48 <VMI398773><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2020-10-12 16:40:48 <VMI398773><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.Last command that was sent was from device 61 as you see in log. That is channel 653.
October 13, 2020 at 11:56 am #7425
MikhailModeratorPlease make screenshots of the related output channels. I need to check their properties, especially formulas.
October 14, 2020 at 8:14 am #7431Marko
ParticipantHello,
The properties of channel 653 and 753 is the same. So i will show you only channel 653.
Here is link about automatic module setup of channel 653:
https://imgur.com/kMkCVfxHere is link about setup of output channel 653:
https://imgur.com/zwimPcLHere is link of formula that channel 653 is using:
https://imgur.com/URjPCceJust to inform you a little better. We using formula to get minute from server time and send it to remote location. It’s like watchdog for remote locations to know when server is down from some reason. Furthermore remote locations send email that server or scada is down. This information is important for us because it’s only way we can detect problems with server or scada automatically.
October 14, 2020 at 2:21 pm #7435
Thank you for the details.
Could you try another approach for the same thing?
Do the following:
1. Make inactive the existing watchdog triggers.
2. Create a new trigger that fires “On channel data change”
3. Create a similar command for the new trigger and tick “Copy value or data” checkbox.
4. Don’t use “Out channel” in the trigger command, but use “Device” and “Command” fields.Please let me know about the result.
October 21, 2020 at 2:31 pm #7450Marko
ParticipantHello Mikhail,
I did change triggers how you mention and server is stable for now. It is working like that for 5 days. I will test it a little bit more and keep you noted.
October 21, 2020 at 2:58 pm #7452
I’m very glad to read that the system is reliable now.
Anyway in the next version Rapid SCADA engine is totally new, and I hope there will be no more such errors.November 20, 2020 at 6:11 pm #7584Marko
just to note that server is stable and wanted to thank you for your support.
November 22, 2020 at 7:09 am #7586
MikhailModeratorGood 🙂
