Scheme copy
Viewing 15 posts - 16 through 30 (of 31 total)
  • #9354
    Another method:
    Hold the Ctrl button and click the components to multiple select.
    Press Ctrl+C to copy components to the clipboard.
    Then choose Edit – Paste Special to paste components.
    Scheme Templates also good, but using many frames may affect performance.
    #9355
    lilytech
    I install the Extra Component Cheme. It has Frame now.
    I make a new sch file, put several Frames on it.
    I have a device file, file name is one-device.sch
    How to set Url for these Frames?
    (note: setting of “../Scheme/Scheme. aspx?viewId=35” does not work).
    #9356
    lilytech
    copy paste works, thank you.
    the problem:
    if I have 128 devices.
    if I need to edit one, all 127 left devices need edit.
    so I still hope to try frame method.
    #9357
    lilytech
    The Gauge in Extra components does not work.
    Should I make payment to make it work?
    If yes, how to make payment? How to get computer code?
    #9359
    In order for the link to work, you need to add this scheme to the views, give it rights, configure the display as a separate view, then you will know its ID, then you insert this view into another scheme with this link. The ID number will be the one that you will be assigned by the system. To hide this view from the list in the tree, you need to set the”Hide” checkbox
    You will still have to create 128 views and hide them, and specify them for frames
    #9360
    You can get a temporary computer code for testing, and you need to pay for the code that will work in the WEB, if you have a separate server, Web server
    #9361
    lilytech
    I try Extra Gauge 1st.
    In a new sch, I only put a gauge, set the Data->input channel.
    In main menu->plugs->installed: the “Extra scheme components” are active.
    Localhost/scada test result shows:
    At Views->new.sch, it shows:
    “Registration failed for “Extra Scheme Components”.”
    “No library found for component extra:Gauge”.
    What is the problem?
    #9362
    Overload the server and also make the Ctrl+F5 command in the browser to update.
    After you have entered the registration key, you need to download the data from the server, and then upload it back to the server.This should be described in the documentation.
    • This reply was modified 5 years, 3 months ago by manjey73.
    #9364
    lilytech
    During installation for extra components, I have not meet “registration key”.
    Where to get it?
    And where is the document link for extra components?
    #9365
    Installation of Webstation Plugins
    7. Download data from the server
    #9366
    2
    3
    But as mentioned above, the page loading will be long, it is still better to make copies of the elements and change the channels. A bit not for such things inserting a schema into another schema
    #9370
    Where to get it?
    After activating the plugin, look in Main Menu – Registration in Webstation
    #9373
    lilytech
    all are ok now.
    #9374
    lilytech
    except the content in the frame can not be loaded even for long long time.
    #9375
    lilytech
    We will waiting for your next version to try.
