Forum Home › Forums › Communicating with Devices › MQTT in-depth Installation Help
- This topic has 25 replies, 9 voices, and was last updated 5 years, 10 months ago by
December 24, 2019 at 2:08 am #6249
ALnaluk
ParticipantError log
https://www.234.in.th/image/0XBMe
And this xml config
<DevTemplate><MqttParams Hostname=”tailor.cloudmqtt.com” ClientID=”” Port=”15043″ UserName=”pscmbdmc” Password=”pscmbdmc”/>
<RapSrvCnf ServerHost=”127.0.0.1″ ServerPort=”10000″ ServerUser=”ScadaComm” ServerPwd=”12345″/>
<MqttSubTopics>
<Topic TopicName=”/mesparam1″ QosLevel=”0″ NumCnl=”600″/>
</MqttSubTopics>
<MqttPubTopics></MqttPubTopics>
<MqttSubCmds></MqttSubCmds>
<MqttSubJSs></MqttSubJSs>
</DevTemplate>
This reply was modified 6 years, 11 months ago by
ALnaluk.
December 24, 2019 at 12:42 pm #6253
greenfoxxParticipantPlease check connect with tailor.cloudmqtt.com using other emulator programs, for example mqtt-spy.
December 25, 2019 at 1:21 am #6260ALnaluk
Participantwhen i use node-red connect cloud mqtt can connected but when i use mqtt-spy doesn’t connect to cloud mqtt
This link video
December 25, 2019 at 1:36 am #6261ALnaluk
Participantnow i can use mqtt-spy connected.help me use rapid scada connect
December 25, 2019 at 6:46 am #6262
phachakornParticipantI also encountered the same problem.
This message in Line Log
2019-12-25 13:40:25 Error executing actions of Device 52 “MQTT” on communication line terminating: Object reference not set to an instance of an object.
2019-12-25 13:40:25 Stop communication line 6 “MQTT”
2019-12-25 13:43:47 Initialize communication line 6 “MQTT”
2019-12-25 13:43:47 Error executing actions of Device 52 “MQTT” on adding device to communication line: Could not find a part of the path ‘C:\SCADA\ScadaComm\Config\’.
2019-12-25 13:43:47 Start communication line 6 “MQTT”2019-12-25 13:43:47 Communication session with the Device 52 “MQTT”, type: KpMqtt
Error reconnecting2019-12-25 13:43:47 Communication session with the Device 52 “MQTT”, type: KpMqtt
Error reconnectingDecember 25, 2019 at 11:26 am #6267
greenfoxxParticipantto phachakorn:
Please check Communication Lines->Request Sequence -> Column Command Line.
You need to write KpMqtt_Config.xml in this column and than Upload Configuration.
If a file name KpMqtt_Config.xml has already been written in this column, just Upload Configuration.to ALnaluk:
Please show connection settings in working mqtt-spy and compare with <MqttParams Hostname=”tailor.cloudmqtt.com” ClientID=”” Port=”15043″ UserName=”pscmbdmc” Password=”pscmbdmc”/>December 25, 2019 at 12:55 pm #6268
greenfoxxParticipantUPD to ALnaluk:
try to Upload Configuration againDecember 26, 2019 at 3:59 am #6273ALnaluk
Participanti can do it.thank you for support
December 26, 2019 at 10:30 am #6275
phachakornParticipantto greenfoxx
it Works.
Thanks you.January 5, 2021 at 8:07 am #7935dinop
ParticipantHello,
I have a problem with MQTT. I followed the instructions of this video: https://www.youtube.com/watch?v=QTcimIik6uU&ab_channel=GreenF, did everything like in the video but I constantly get this messages.
2021-01-05 08:57:31 Communication session with the Device 42 “MQTT”, type: KpMqtt
Error reconnecting2021-01-05 08:57:31 Communication session with the Device 42 “MQTT”, type: KpMqtt
Error reconnectingScreenshoots of setup I made:
https://ibb.co/Lg6sxwr
https://ibb.co/nmqHDbT
https://ibb.co/s3N7QXV
https://ibb.co/nBKbXrf
https://ibb.co/q5gtk7YPlease provide me some feeback and let me know what I am doing wrong.
Thanks in advanceJanuary 5, 2021 at 1:38 pm #7945
Try installing the up to date version of KpMqtt.dll. May be it doesn’t fix the error, but the new version provides the detailed error message (link).
