Forum Home › Forums › Development and Integration › Mobile client and Rapid SCADA
- This topic has 27 replies, 6 voices, and was last updated 6 years, 5 months ago by
May 8, 2020 at 1:27 pm #6814
manjey73ParticipantPort forwarding for example
Checking the IP provider, it is not a fact that you will be able to connect to it, since it may be for NAT
For example, routers Zyxel, Mikrotik and perhaps others have a cloud service to access them, then instead of an IP address, you need to know the name that the router manufacturer provides you with
xxxxxxxxxxxa.sn.mynetname.net – On my Mikrotik it looks like this (instead of xxxxx numbers)
May 8, 2020 at 4:37 pm #6819arvxn01
ParticipantHello @manjey73,
I have a router from SFR and there is no cloud service integrated. Maybe I need to try noip.com as Mikhail said :
“Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scada”
I will try this solution.
May 8, 2020 at 5:20 pm #6821arvxn01
ParticipantThanks you @manjey73 !
Port forwarding is the solution for my project. I use noip.com to bypass dynamic IP adress and access when I went to my webserver using ports 80 and 443.
May 8, 2020 at 5:22 pm #6822
Hennie_KotzeParticipantDear @arvxn01,
In my case I had to request my service provider (Vodacom) to change my restricted APN to UN-restricted. Even while using noip, it did not work through the restricted APN.
Hope it helps??…….
Regards,
May 8, 2020 at 7:07 pm #6823
manjey73ParticipantThere are just real dynamic addresses, and there are dynamic addresses located behind the provider’s NAT. In the second case, only cloud services or VPN services can help (but I have not met third-party vpn services that would allow you to connect two clients to each other)
May 8, 2020 at 11:20 pm #6824arvxn01
ParticipantGood morning,
I set up port forwarding on my router and I use noip.com to haven’t problem with the dynamic IP adress of my router.
For my project, everything work perfectly ! Thanks to @manjey73 and @Hennie_Kotze ! I can connect to the webstation on my iPhone even if I use cellular network.[1 question remaining]: I saw on my iPhone and on my PC that the connection is not secured. Is it possible to change settings to have a secured connection or there is no way ?
May 9, 2020 at 6:56 am #6825
manjey73ParticipantYou need to transfer Apache2 or IIS to work on https. I didn’t do this myself, but the topic on the Russian forum may help, and Mikhail will write more details
May 9, 2020 at 7:05 am #6829
manjey73ParticipantThere is another option, you disable the web port forwarding. Create a VPN server on your router. When you need to, connect via your phone as a VPN client and then go to the WEB at the internal address of your server. The VPN client must be able to route the connection to the internal network. One of the advantages of this solution, depending on the settings, your phone when accessing the Internet will be determined with the IP that you have at home
May 16, 2020 at 2:15 pm #6840arvxn01
I have 2 questions :
1) How can i create a new topic ?
2) I need to setup two webstations. One with buttons, switchs and leds. And the other one will show a part of a production line with engines, and others devices. These webstations need to communicate using Internet. How can I do this installation with RapidScada ?
May 16, 2020 at 3:48 pm #6841arvxn01
ParticipantI try to use many instances inside the same project but i didn’t succeed. I didn’t find any video about instances. Can you explain me how i can use many instances in the same project. And what i can do with many instances ?
For now, when i create a profile for a new instance, he doesn’t work and the error says “Unable to login – System instance not found”.May 17, 2020 at 8:02 am #6842
MikhailModeratorHow can i create a new topic ?
Click the appropriate subforum, scroll the page down, fill and submit the form.
Please create a new topic for this question.
May 21, 2020 at 12:11 pm #6858arvxn01
ParticipantHey @manjey73 @Mikhail @Hennie_Kotze
I have 2 computers with Rapid SCADA so 2 different projects.
The 1st project for simulating. And the 2nd project for control the simulated system. I don’t know if I need to use port forwarding on my router or use the firewall with advanced settings ? Because, I want the 2nd project controls the simulated system using Internet connection.Please for your future answer 🙂
May 21, 2020 at 2:29 pm #6862 -
