Forum Home › Forums › Understanding the Software › Events trigger and colors
- This topic has 20 replies, 3 voices, and was last updated 6 years, 1 month ago by
October 30, 2018 at 5:23 pm #4520
MikhailModeratorThanks!
November 28, 2019 at 9:26 am #6094SGG
ParticipantHello Mikhail,
I have been trying to invert the status color for input channel following your instruction but no success yet.
i want:
“OFF” to be “NORMAL” with color GREEN.
“ON” to be “FAULT” with color RED.
So i created my own record in the unit table, “NORMAL; FAULT.
Then used a formula at input channel. The formula used is (Cnl; Cnl > 0 ? 114 : 101)
Thanks for your advice.
November 28, 2019 at 12:07 pm #6099
If the above message contains a question, please do the following:
1. Make screenshots of the settings you already did.
2. Describe the actual behavior.
3. Describe the needed behavior.November 28, 2019 at 1:32 pm #6101SGG
I have been trying to invert the status color for input channel following your instruction but I have no success yet.
ACTUAL BEHAVIOR:
I created my own record in the unit table of administrator, “ NORMAL; FAULT “.when the input channel state is NORMAL, the color of the text is RED and when the input channel state is FAULT, the color of the text is GREEN.
I tried using the formula (Cnl; Cnl > 0 ? 114 : 101) to revert the color so that “NORMAL” text will be GREEN and “FAULT” text will be RED.
Screenshot of my settings are shown below:
Event type:
Unit type:
Input type:
NEEDED BEHAVIOR:
I want the “NORMAL” text to be GREEN and “FAULT” text to be RED.
Help me correct any possible error.
Thanks for your advice.November 28, 2019 at 1:36 pm #6102SGG
ParticipantPlease the image of my setting
Event type:
https://drive.google.com/file/d/1I2TVYQWIYExsYXoi3cRriYh7lFyJWoNn/view?usp=sharingUnit type:
https://drive.google.com/file/d/1bBsNu1bxYPbepdL8Hu106t9sUmerpSTi/view?usp=sharingInput type:
https://drive.google.com/file/d/1KiFcUYPWOraU08ovVcj8IubA9pEApfti/view?usp=sharing-
This reply was modified 6 years, 1 month ago by
November 29, 2019 at 3:13 pm #6113
MikhailModeratorThank you for the explanation.
In the Units table set the Sign column like that: Normal; Fault; –
You need 3 elements to make colors work. I think, we will change the behavior in the future, but now if there is only 2 elements, colors always red and green. -
