Forum Home › Forums › Understanding the Software › Displaying string instead of input
Tagged: counter, formula, input channels, string, Table
- This topic has 23 replies, 8 voices, and was last updated 1 year, 11 months ago by
October 25, 2021 at 12:39 pm #9587
It’s possible. But the subject of this topic is not appropriate the question. Please create a new topic to discuss.
December 1, 2024 at 8:23 pm #15689Ashashash
ParticipantHello Mikhail,
I use 6.2.1.1 version,
I need to display text values instead of input numberic value,
But tried Formats, also Units. Seems all options are limited to text size 1000 symbols.
Is there an option to use 20000 or more symbol formula?December 2, 2024 at 9:37 am #15693
Probably, another solution is needed in that case. Please provide screenshots of your settings for better understanding.December 2, 2024 at 10:40 am #15694Ashashash
ParticipantOk, for example:
if input 1001 value is:
434.081, I need text to be displayed “Error +10V ref. sensor system : I/O board control cabinet”;
233.001 -General warning message : software update required;
62.031 -Feeding fault : System circuit breaker off;
60.010 -Mains failure : Overvoltage L1+L2+L3;
60.028 -Mains failure : Overfrequency (restart).And so on. Few hundred lines like this.
Also for different equipment different set of textsDecember 3, 2024 at 9:54 am #15703
MikhailModeratorFor such long messages, create a function that returns a string and use it for an input channel.
For example:public string MyString() { if (Cnl < 0) return "Abc"; else return "Cde"; }In the channel input formula:
MyString()December 17, 2024 at 7:47 pm #15820Jorge
ParticipantHi, I have a similar question. I am receiving data via MQTT and getting an 8-bit binary that I want to convert to an ASCII character. I am doing the conversion in the JS file, but when I try to put the character in a view table, I get an error.
Communication line error:
js file:
December 18, 2024 at 12:26 pm #15821
The MQTT client driver supports only numbers.December 20, 2024 at 2:33 pm #15828rsepulve
ParticipantHi Mikhail,
This is Rodrigo Sepulveda, from Chile.
I have an issue.I have the folowing payload from UG56 Milesight Lora gateway.
{“adc_1”: 4, “adc_2”: 4, “applicationID”: 1, “devEUI”: “24e124445d182905”,
“deviceName”: “VDBT-TDC-03”, “gpio_counter_1”: 4018, “gpio_input_2”: 0,
“gpio_input_3”: 0, “gpio_input_4”: 1, “gpio_output_1”: 0, “gpio_output_2”: 0,
“modbus_chn_2_alarm”: 1}but the original from field, from Milesight UC300 device is:
{“adc_1”: 4, “adc_2”: 4, “gpio_counter_1”: 4018, “gpio_input_2”: 0, “gpio_input_3”: 0, “gpio_input_4”: 1, “gpio_output_1”: 0, “gpio_output_2”: 0,
“modbus_chn_2_alarm”: 1}But, I canĀ“t take off this 3 elements thats UG56 gateways add:
“applicationID”: 1, “devEUI”: “24e124445d182905”, “deviceName”: “VDBT-TDC-03”
This cause an error in MQTT communications lines.
2024-12-20 11:31:38 Receive biocorneche/vdbt/pla/gbtes/24e124445d183109/up = {“adc_1″:4,”adc_2”:0…
Subscribed devices: 3
Hello from JS. Topic: biocorneche/vdbt/pla/gbtes/24e124445d183109/up
Error: The input string ’24e124445d183109′ was not in a correct format.How can I fix or ignore those strings?
Thanks.December 23, 2024 at 11:13 am #15830
MikhailModeratorHi Rodrigo,
Your question is about MQTT, not related the current topic of displaying strings.
Please start a new topic to discuss the question. Provide screenshots of the MQTT configuration and logs. -
