Chart Pro with application error
Forum Home › Forums › Installation Issues › Chart Pro with application error
Viewing 2 posts - 16 through 17 (of 17 total)
  • #8726
    hethongscada62
    Dear Mr.Mikhail,
    After writing an access to the configuration directory and configuration file, i can not get the result. Can not save Configuration”. The notices appears likes these:
    “Error saving web application settings: Access to the path “/var/www/html/scada/config/WebSettings.xml.bak” is denied.”
    “Application Error
    Details:
    Method not found: !!0 Scada.Web.WebUtils.GetParamAsEnum<!0>(System.Collections.Specialized.NameValueCollection,string,!!0)”
    https://ibb.co/37SMHdx
    https://ibb.co/y8DksVq
    Where is the wrong?
    Thanks a lot
    #8745
    “Method not found” error is caused because of Webstation version and the plugin version mismatch.
    The second screenshot: provide access right to all files in the config directory.
