Forum Home › Forums › Understanding the Software › Formulas › Can we use Scheme to change Input channel value
- This topic has 21 replies, 2 voices, and was last updated 7 years, 7 months ago by
April 22, 2019 at 2:33 pm #5344
scadarapid
ParticipantAutomatic control
https://www.img.live/image/7UozsE
https://www.img.live/image/7Uo2jK
https://www.img.live/image/7UoHLr
https://www.img.live/image/7Uobut
formula
https://www.img.live/image/7UopeZ
output channel
https://www.img.live/image/7UoXKR
input channel
https://www.img.live/image/7UoftiApril 22, 2019 at 2:55 pm #5345scadarapid
Participantthe problem.
i use automatic control to send data to my input channel that I has extra create.
when automatic control send data to my extra input channel. the server will be error.from the picture input
extra Input channels number 9009-9016 my enable input channel that receives data from toggle scheme.
extra input channels number 9017-9026 my time zone input channel that receives data from automatic control. the value will change when i set the time at automatic control module such as when 9AM set 1 to output channel number 9017
extra input channels number 9027 – 9034.from the picture output
9009-9016 output channels that receive data from toggle scheme
9017-9026 output channels that receive data from automatic controlthank you so much.
April 23, 2019 at 1:21 pm #5350
MikhailModeratorthe server will be error.
I can’t find neither screenshot nor log message of the error. Could you provide it?
April 24, 2019 at 8:15 am #5353scadarapid
ParticipantMy ScadaCommSvc.log —> sometime I can send commands to my output, sometime i cannot send command to my output.
From ScadaCommSvc.log
2019-04-24 15:06:30 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:31 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:32 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:32 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error connecting to SCADA-Server: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:06:37 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:38 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:39 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:40 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:41 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:42 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:42 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error connecting to SCADA-Server: No connection could be made because the target machine actively refused it 127.0.0.1:10000
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:06:43 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:44 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:45 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:46 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:47 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:48 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:49 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:50 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:51 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:52 <DESKTOP-1CTUDRI><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
2019-04-24 15:06:52 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:07:24 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error requesting telecommand from SCADA-Server: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.
2019-04-24 15:07:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:07:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><EXC> Error requesting telecommand from SCADA-Server: Unable to read data from the transport connection: An established connection was aborted by the software in your host machine.
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><ACT> Disconnect from SCADA-Server
2019-04-24 15:07:26 <DESKTOP-1CTUDRI><SYSTEM><ACT> Connect to SCADA-Server “localhost”
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=1
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=2
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=3
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=4
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=5
2019-04-24 15:08:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=6
2019-04-24 15:08:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=7
2019-04-24 15:08:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> The command is received from SCADA-Server: type=Standard, device=99, number=8April 24, 2019 at 8:18 am #5354scadarapid
ParticipantScadaServer.log
ived from the client 127.0.0.1
2019-04-24 15:14:57 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:14:58 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:14:59 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the minute data table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the minute data copy table is completed
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:00 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:01 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:02 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:03 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:04 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:05 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:06 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:07 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:08 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:09 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:10 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:11 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:12 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:13 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:14 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:15 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:16 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:17 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:18 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:19 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:20 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\BaseDAT\incnl.dat
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:21 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:22 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x08 (open and read file) is received from the client 127.0.0.1
2019-04-24 15:15:23 <DESKTOP-1CTUDRI><SYSTEM><ACT> Opening file C:\SCADA\ArchiveDAT\Cur\current.dat
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x0C (request files modification time) is received from the client 127.0.0.1
2019-04-24 15:15:24 <DESKTOP-1CTUDRI><SYSTEM><ACT> Obtaining the modification time of the file C:\SCADA\ArchiveDAT\Events\e190424.dat
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data table is completed
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Writing snapshot in the current data copy table is completed
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1
2019-04-24 15:15:25 <DESKTOP-1CTUDRI><SYSTEM><ACT> Command 0x07 (request command) is received from the client 127.0.0.1April 24, 2019 at 8:20 am #5355scadarapid
ParticipantWhen I can not send the command to my output the server will be error, I have to restart the server, then the server will comeback.
April 24, 2019 at 1:32 pm #5362 -
