Forum Home › Forums › Understanding the Software › SMS GSM Cinterion Modem
- This topic has 24 replies, 4 voices, and was last updated 3 years, 9 months ago by
November 12, 2018 at 3:30 am #4581
bencyau
ParticipantHello,
As I am looking into sending SMS, the default device Cinterion MC52iT is now “discontinued”.
Is there another modem anyone know that works?How about Cinterion GSM & GPRS Module BGS2T RS-232, which is still available for purchase?
Are there now other ways to send SMS, such as online tools?
Thanks.
November 12, 2018 at 2:08 pm #4582
I suppose, all Cinterion modems should works. However, I have no such information. Ask their support for compatibility with MC52iT in part of sending SMS.
Of course. Look for a SMS provider in your country which support HTTP API for sending SMS. There is a driver named KpHttpNotif.dll that allows sending custom HTTP requests with SMS parameters.
November 14, 2018 at 8:51 am #4590bencyau
ParticipantThank you for above reply.
I posted my ScadaAdmin issue in another topic, but here want to continue testing the SMS feature.
I got a 232 modem, and connected it to COM4. Modified the ScadaComm / GSM / serial port to match. Turned it to Active.
The Communication Line State: running, COM4(open). Active Devices: normal.Line 3″GSM” / Request Sequence / Cinterion / call number set to my mobile phone.
From here on, how do I manually send a test string SMS? Actually, how do I use the “address book” entries?
If it is similar to OPC, then I should do Device 31 / Commands.Thank you.
November 14, 2018 at 6:14 pm #4594
In Communicator select Device Libraries node and then KpSms.dll. You will find command examples to send SMS.
email;message – means phone_number;message
November 15, 2018 at 1:28 am #4596bencyau
ParticipantGreat! SMS sent via the command tab. Thank you.
Later will test the automatic control send.November 15, 2018 at 6:45 pm #4600
MikhailModerator🙂
September 25, 2020 at 8:58 am #7306Krzysztof
ParticipantMikhail, I am confused if KpHttpNotify.dll exists? The post shows that yes, but I don’t see this driver in the catalog, nor can I download additional free or commercial drivers from the options. What does it really look like?
September 25, 2020 at 1:40 pm #7307
MikhailModeratorThis driver is not official, however, it exists. Updated link
September 25, 2020 at 1:41 pm #7308January 3, 2023 at 2:10 am #11851hethongscada62
ParticipantDear Mr.Mikhail and All,
Rapid scada can use a Module SIM808 (GSM/GPRS/GPS/BLE Module) for sending SMS?
Thanks and best regards
Han HoangJanuary 3, 2023 at 8:23 am #11852
MikhailModeratorDear Han,
Rapid SCADA includes a driver KpSms.dll that supports AT command set for sending SMS. To answer if a certain module works with the driver or not, you should test them together.January 3, 2023 at 8:43 am #11854hethongscada62
ParticipantDear Mr.Mikhail.
Yes, I see the driver KpSms.dll that supports both types SMS command and AT command set for sending SMS, but I did not see a custom AT command text example likes the Sending SMS command text examples:
group_name;message
contact_name;message
Could let me know a text examples when using custom AT command?
Han HoangJanuary 4, 2023 at 12:33 pm #11876
When you send a custom command, the driver sends data that is specified for the command.January 11, 2023 at 8:23 am #11944hethongscada62
ParticipantDear Mr.Mikhail and All.
The Module SIM808 (GSM/GPRS/GPS/BLE Module) is testing now.
https://ibb.co/tQvb70M
You can see a screenshot bellow:
It is not working, it is?
Could You let me know?
Han HoangJanuary 11, 2023 at 1:40 pm #11946
SIM808 replies “ERROR” for message list request.
Did you try to send messages by commands? -
