Forum Home › Forums › Understanding the Software › Sending email by using Gmail sudden fail
- This topic has 39 replies, 6 voices, and was last updated 3 years, 5 months ago by
hethongscada62.
June 14, 2022 at 8:53 am #10344
kcks66
ParticipantHi Mikhail,
I am using email function configured by using Gmail smtp so far so good until recent Google announced “Less Secure App Access” option was no longer available. I set the Less Secure App Access to ON and enable IMAP previously. Now you can see from the below image that suddenly Gmail reject Rapid SCADA to access my google account.
Rapid SCADA email configuration image as below.
Pls advice for is there anything I can do to have the email sending function resume working fine?
June 14, 2022 at 3:33 pm #10345
As I understand, Google does not allow 3rd party application to send emails any more.
You should use another email service.
For example, in my country https://yandex.com is popular.
Mail servers may use various server host and port, different than Google. Check their manuals.-
This reply was modified 4 years, 4 months ago by
June 15, 2022 at 12:48 pm #10351kcks66
Noted that I should use another email service. I setup an account from yandex email service as per your suggest.
However, I couldn’t make the email sender work; I got error message:
My email sender setting:
Pls advice for is there anything else I need to do?
Thank you.June 15, 2022 at 2:12 pm #10352
Try port 25June 16, 2022 at 9:46 am #10355kcks66
Port 25 gave another new error message:
Error sending email to cho.keat.seong@gmail.com: Bad sequence of commands. The server response was: 5.5.4 Error: send AUTH command first. 1655372643-0Hlz4rXRDy-i3MmpLEF
Pls advice and thank you.
June 17, 2022 at 11:03 am #10358
Check the settings:
https://ibb.co/hKd7VfTJune 17, 2022 at 1:25 pm #10361kcks66
Thanks for the Yandex setting. I tested by using Communicator Email Command, it went through but Yandex treat it as spam.
Error sending email to cho.keat.seong@gmail.com: Transaction failed. The server response was: 5.7.1 Message rejected under suspicion of SPAM; https://ya.cc/1IrBc 1655471924-o4ZxzWO5VS-IgMqIU61
June 19, 2022 at 6:56 am #10362
May be you should try sending email with simple text.
I suggest to contact Yandex technical support.June 25, 2022 at 6:24 am #10383kcks66
Email was successfully sent out by simple text.
Thank you.August 19, 2022 at 6:48 am #10494PVO
I have a similar problem as the one mentioned in this topic.
Since gmail no longer emailing without verification, I tried to configure yandex mail account.Server host: smtp.yandex.com
Port: I tried both 25 and 465
User: my yandex e-mailadres (I tried with and without @yandex.com)
SSL is ON.I always get a time out when trying to send an e-mail…
Kr,
PhilippeAugust 19, 2022 at 11:54 am #10498
Users say that you should create an external application in Yandex and set password for it. Translate this post.February 2, 2023 at 4:04 am #12062hethongscada62
ParticipantDear Mr. Mikhail,
The Email driver have been installed in Windows for testing. It works perfectly when I send email directly via command of device. Then this Email driver installed in Raspberry Pi4.
https://imgbb.su/image/xJK1V6
It not works via Automatic Control module.
https://imgbb.su/image/xJKrDE
https://imgbb.su/image/xJKPhS
May be the configure of Automatic control is wrong, isn’t?
https://imgbb.su/image/xJT4VC
Could you check and let me know.
Thanks a lot
Sorry I wasted your much time
Han HoangFebruary 2, 2023 at 9:34 am #12065
In the communication line log, there is an error on loading the Email Driver settings.
You should check that the driver version on Windows and on RPi are the same. Use the up to date version.February 3, 2023 at 5:17 pm #12068hethongscada62
Thank you for your reply,
After checking the date version, reboot a RPi. The status of device that seems is normal, but after refreshing RPi, the status of device is error.
https://imgbb.su/image/xgEHFw
https://imgbb.su/image/xgEbQc
https://imgbb.su/image/xgE3IQ
https://imgbb.su/image/xgENDl
Where is wrong?
Thanks a lot
Han HoangFebruary 4, 2023 at 11:15 am #12069
victorlamParticipantHello Han Hoang,
I would like to learn to use email sending to remind the user.
Can you help to share some settings how you can configure here?Thanks!!
Victor
