Forum Home › Forums › New Ideas › scheme editor
- This topic has 16 replies, 3 voices, and was last updated 5 years, 4 months ago by
Zeus.
May 6, 2021 at 1:27 pm #8877
ZeusParticipanthi
I am trying to edit a page.
I found it not convenient to edit the page because there is no auxiliary line to help me put materials on the page. will there be auxiliary lines? it will be helpful. the pictrue is below. the first one is now we are using. the second picture is what we need.https://ibb.co/wstnmph
https://ibb.co/wstnmphhttps://ibb.co/JrVmq0QMay 6, 2021 at 1:29 pm #8878
ZeusParticipantMay 9, 2021 at 7:35 am #8892
ZeusParticipanthi,
i have tried to solve but there are still many problem. hope you can develop it in scheme editor
https://ibb.co/Tkg8LSwMay 9, 2021 at 9:18 am #8897
Align feature will be added, because it’s really needed.
Thank you for additional notification about that.May 10, 2021 at 1:07 am #8903
ZeusParticipanthi,
I really love this project.
I have developed driver IEC104 and IEC61850.
I have developed mod Influxdb and Redis.
I have developed plugs such as Hikvision camera with controls, data analysis module and Echart.May 10, 2021 at 5:15 am #8905
manjey73ParticipantWould you share the IEC104 driver ?
May 10, 2021 at 1:17 pm #8912
The mentioned drivers and modules are very useful. That’s great!
Are documentation or videos available?
Do you have plans to spread the modules?May 11, 2021 at 1:37 am #8921
ZeusParticipanthi
these drivers and modules are still in development. there are still many changes and bugs in testing.
I have a new idea about the scheme editor. the web station does not have self-adapting in different screens on different DPI. do you have a plan to solve that? I used to use some form editors. they use the bootstrap layout. it has rows and columns. we can drag them in the web station that can fit any screens on different DPI.
the height of components we can use calc(100vh-px) or another way.I used to use razor page mix vue.js in net core3.1. it is convenient to handle data and easy to develop.
May 11, 2021 at 1:41 am #8922
ZeusParticipanthi
this is an online form editor. you can try it out.
https://ibb.co/6s4xLXP
the link address is below.
http://form.making.link/basic-version/#/zh-CN/May 11, 2021 at 1:50 am #8923
ZeusParticipanthi
will the V6 version save current data per second? now I use modinfluxdb driver to save current data in influxdb. but it is not convenient. that will be great if the V6 version supports current data saved in cur.dat file per second. we can do more analysis work on it. now the v5 version only saves minute data and hour data.May 11, 2021 at 3:21 am #8924
ZeusParticipantMay 11, 2021 at 10:22 am #8927
manjey73ParticipantOn the current version and earlier, you can save data every second, you need to change it manually in one of the configuration files.
May 11, 2021 at 12:57 pm #8932
It will write data to archives with any period.
It is not a scheme approach. I would call it dashboards. The existing Dashboard plugin also uses Bootstrap. Welcome the creation of different types of views.
May 11, 2021 at 12:59 pm #8933
MikhailModerator@q383186554, your developments are quite interesting.
When you create a production version, let the people know about that.May 13, 2021 at 7:25 am #8944
ZeusParticipanthi
we change the code and make it able to speak text.
https://ibb.co/z2xNp6H -
