Forum Home › Forums › Installation Issues › SCADA-Web Installation › Scada webstation not getting open
- This topic has 15 replies, 7 voices, and was last updated 4 months, 3 weeks ago by
April 7, 2025 at 12:09 pm #16316
hellovijay78
ParticipantDear sirs,
I had istalled the Rapid SCADA in my windows 10 proffessional 64 bit. I had installed it with the help of video instruction in the site. All the area was successful as per the video but when I open webstation I am getting an error message.The error message is “HTTP Error 500.19 – Internal Server Error”. Will you please help me to install and use it? Please.April 8, 2025 at 9:52 am #16320
Please check the ScadaWeb.log file for the error details.April 10, 2025 at 3:30 pm #16338Sparkle75
ParticipantI have a full view on my localhost computer if I open the web page up either as localhost or using its IP address. I can also log in on a remote computer using the Webstation host computer’s IP address. However, I see no data on the remote computer, as shown in the attached picture. This is sooo close to working properly, but I just can’t determine what I am doing wrong.
https://drive.google.com/file/d/1XqHNYqGkgXJOtcvXfnNa5XhyCqPQ-qTA/view?usp=drive_linkhttps://drive.google.com/file/d/1iplEw68bVb6PpOYLhEcmr5enVg6S1ygy/view?usp=drive_link
Webstation log shows it is operating with no errors.
April 11, 2025 at 2:52 pm #16340
The web browser in the 2nd picture looks very old. You should update the browser to the latest version.April 11, 2025 at 3:49 pm #16343Sparkle75
ParticipantThat was the solution. The older machine close to my area is not capable enough. I tried it in another area of the plant with non-vintage computers and it works just fine! Thank you!
April 14, 2025 at 11:25 am #16344
MikhailModerator🙂
July 10, 2025 at 11:31 am #16640Mani_TheCat
ParticipantHi Mikhail,
I’m having the same issue after installation where I cannot open the workstation. I don’t know how to check the ScadaWeb.log file. Can you please help me with it?
July 10, 2025 at 11:43 am #16641Mani_TheCat
ParticipantThis is what Im seeing :
<configuration>
<location path=”.” inheritInChildApplications=”false”>
<system.webServer>
<handlers>
<add name=”aspNetCore” path=”*” verb=”*” modules=”AspNetCoreModuleV2″ resourceType=”Unspecified” />
</handlers>
<aspNetCore processPath=”dotnet” arguments=”.\ScadaWeb.dll” stdoutLogEnabled=”false” stdoutLogFile=”.\logs\stdout” hostingModel=”inprocess” />
</system.webServer>
</location>
</configuration>
<!–ProjectGuid: b4495bf2-c904-4bfe-bf3b-fe38cf0fc378–>July 11, 2025 at 10:45 am #16653
What do you see in the modules window?
Note that ASP.NET 8 must be installed after IIS.July 11, 2025 at 11:24 am #16656Mani_TheCat
ParticipantYah the ASPNetCoreModuleV2 was not showing before in my IIS. And I had to look and download and that fixed the issue.
By any chance can you link me with some example projects backup? I will try to restore the project and learn from there.
My main idea is to just display values in a table format directly read from Modbus device and store it in a database for historical retrieval and viewing.
If you can provide me a project that closely resembles to my scope that will be awesome
Thanks,
July 14, 2025 at 11:02 am #16667
MikhailModeratorcan you link me with some example projects backup? I will try to restore the project and learn from there.
The Hello World project is in C:\Program Files\SCADA\ProjectSamples\HelloWorld
Other projects are owned by the customers.
There is a YouTube video about connecting devices by Modbus. It should not be hard.January 11, 2026 at 2:30 pm #17537fischerp
ParticipantHello,
I have the same problem as described above and don’t understand the proposed solutions. The version is 6.2.2.
To describe the problem precisely: When I try to open the web interface with “localhost:10008,” I get the following error:
HTTP-Fehler 500.19 – Internal Server Error
Auf die angeforderte Seite kann nicht zugegriffen werden, da die zugehörigen Konfigurationsdaten für die Seite ungültig sind.
(that means: The requested page cannot be accessed because the configuration data for the page is invalid.)
Rapid scada is installed by the setup.exe. Rapid Scada was installed with ScadaSetup. Various dependencies were missing, which were flagged during installation and were installed or activated by me. The installation process was then completed without errors. I then opened the sample project. The log files shown in the installation video display the same content for me as in the video.
Is there a setting missing here?
Do I need to start another service?
ScadaAgent
ScadaComm
ScadaServer
have been startedJanuary 12, 2026 at 10:06 am #17540
The issue is somewhere in IIS configuration.
Could you make a screenshot of your IIS management console?
Especially the modules section. ExampleJanuary 17, 2026 at 10:42 am #17568Gabor
ParticipantHello! I had issue installing Rapid Scada (came with error) on Windows7 and make the Webstation to work, when I realized one of the comment said Win7 is no longer supporter (however rapidscada.net stated win7 is supported with SP1, but now I see its for the old documentation) So a bit confusing,as I am new to Scada.
Also noticed Rapid Scada is no longer Free?
I mean if we want to make working projects with tags (sensor input reading,plc,visualization,etc) it is not free anymore.. Just wanted to confirm.
Thank youJanuary 17, 2026 at 11:29 am #17569
manjey73ParticipantThe scada core itself is free and open source. There have always been paid components that you can do without, except in some cases.
someone installed dancing and tambourine on Winows 7. but in general, yes, it’s better to use Windows 10 or 11.
