Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Scada Agent error
- This topic has 15 replies, 2 voices, and was last updated 5 years ago by
February 23, 2021 at 11:11 am #8313
fedex
I want to upload a project from windows pc to raspberry.
I have this error:Error Uploading configuration. There was no endpoint listening at http://192.168.1.3:10002/ScadaAgent/ScadaAgentSvc/
I have this error when starting the scada agent service, and the log file is not created in /opt/scada/ScadaAgent/Log:
pi@raspberry:~ $ sudo service scadaagent status
● scadaagent.service – LSB: SCADA-Agent daemon
Loaded: loaded (/etc/init.d/scadaagent; generated; vendor preset: enabled)
Active: active (exited) since Tue 2021-02-23 11:39:19 CET; 10min ago
Docs: man:systemd-sysv-generator(8)
Process: 1969 ExecStop=/etc/init.d/scadaagent stop (code=exited, status=0/SUCCESS)
Process: 2091 ExecStart=/etc/init.d/scadaagent start (code=exited, status=0/SUCCESS)Feb 23 11:39:19 raspberry systemd[1]: Starting LSB: SCADA-Agent daemon…
Feb 23 11:39:19 raspberry scadaagent[2091]: Delete ./Cmd/agentstop
Feb 23 11:39:19 raspberry scadaagent[2091]: Sending start SCADA-Agent command…
Feb 23 11:39:19 raspberry scadaagent[2091]: Start SCADA-Agent command is sent
Feb 23 11:39:19 raspberry systemd[1]: Started LSB: SCADA-Agent daemon.
Feb 23 11:39:19 raspberry scadaagent[2091]: Unhandled Exception:
Feb 23 11:39:19 raspberry scadaagent[2091]: System.IO.FileNotFoundException: Could not load file or assembly or one of its dependencies.
Feb 23 11:39:19 raspberry scadaagent[2091]: File name: ‘netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’Can you help me, thanks
February 23, 2021 at 11:26 am #8315
Looks like the Agent application was not installed on RPi. Are there any files in /opt/scada/ScadaAgent directory?
February 23, 2021 at 11:28 am #8316
MikhailModeratorIf the files presented, try the command line
mono /opt/scada/ScadaAgent/ScadaAgentMono.exeFebruary 23, 2021 at 12:03 pm #8317fedex
the files are present.
The web application works with the sample project.
This is the error:
pi@raspberry:~ $ mono /opt/scada/ScadaAgent/ScadaAgentMono.exeUnhandled Exception:
File name: ‘netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’Thanks
February 24, 2021 at 4:29 pm #8321fedex
Can you help me, thanksFebruary 24, 2021 at 4:41 pm #8322
Please check the version of Mono Framework by the command
mono --versionFebruary 24, 2021 at 5:17 pm #8323fedex
now i can’t check.
What is the correct version?February 24, 2021 at 7:13 pm #8324fedex
this is the version:
Mono JIT compiler version 4.6.2 (Debian 4.6.2.7+dfsg-1)February 25, 2021 at 1:08 pm #8326February 26, 2021 at 6:30 pm #8337fedex
i installed version 6 of mono, but now i get this error from the web application:Description: HTTP 404.The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Details: Requested URL: /scada/
No log in /opt/scada/ScadaWeb/log
What can I check?
thank you.-
This reply was modified 5 years ago by
fedex.
March 1, 2021 at 8:46 am #8356
Try repeating the installation steps related to the web application.March 1, 2021 at 8:58 am #8360fedex
i tried, with version 4 of mono, the web application worked.March 1, 2021 at 11:32 am #8363fedex
the problem is the link to the web application:
sudo ln -s /opt/scada/ScadaWeb /var/www/html/scada
I copied ScadaWeb into /var/www/html/scada and it works.
Do you have ideas to solve the problem?March 2, 2021 at 2:44 pm #8378
It may be an access rights problem.
When link is created, it works similar like copying files into the target directory.March 2, 2021 at 2:48 pm #8382fedex
can you tell me what to check?
I have made some tests but I cannot solve the problem. -
