Responsive Web Design
Forum Home Forums New Ideas Responsive Web Design
  • #3937
    leon
    Hi
    Will you consider adding RWD(Responsive Web Design) feature in the future?
    Thanks!
    • This topic was modified 8 years ago by leon.
    #3941
    Rapid SCADA works on different devices and different screens. If some layout is not optimal, let’s discuss in particular.
    #3942
    leon
    Hi
    Thank you for your example.
    Because buttons and displays are placed on the basemap.
    Basemaps need to be manually zoomed in or out on different devices and on different screens.
    • This reply was modified 8 years ago by leon.
    #3952
    Could you provide an example of a basemap?
    #3957
    leon
    Hi
    I put three buttons on the basemap.
    He is normal.
    https://imgur.com/a/tchy5rI
    Thanks!
    #3959
    I’m sure how do you expect them to work.
    #4006
    leon
    hi
    I have a problem. SchemeEditor-Toggle resolution is abnormal.
    https://imgur.com/a/3pE58qZ
    #4008
    How to reproduce the issue on my side?
    #4009
    leon
    hi
    Provide Interface to you?
    from email
    #4011
    leon
    leon
    ZOOM IN is normal
    ZOOM OUT is abnormal
    #4013
    leon
    I will check and write here.
    #4026
    The bug is fixed and the fix will be included in the next version of Rapid SCADA in August or September.
    Thank you for your help.
