Open in Web Browser
Forum Home › Forums › Understanding the Software › Open in Web Browser
Viewing 15 posts - 1 through 15 (of 23 total)
  • #6463
    joeh6966
    Error message “The requested view does not exist or you have insufficient rights to access it.”
    I saw your video showing putting in the Folder and File names in the Interface node. I did that, saved it and uploaded it to no avail.
    https://ibb.co/0crj37w
    What am I doing wrong?
    I want to see the log of the readings taken every hour.
    • This topic was modified 6 years, 9 months ago by Mikhail.
    #6464
    You also need to allow viewing and managing in the Rule tab
    #6466
    joeh6966
    I can’t find any “Rule” tab.
    #6467
    Rights, access Rules, Access, I don’t know how to call it correctly in the English version.
    I use an online translator
    • This reply was modified 6 years, 9 months ago by manjey73.
    #6469
    joeh6966
    So many problems.
    I found Roles, Users and Rights. I don’t understand Roles or Rights, but I edited the Users to Administrator in 2 cases.
    https://ibb.co/fNMbCcd
    I get a different error message, Server is unavailable, instead of I don’t have permission.
    #6471
    This is a different table . There are not so many tables in the project that you can’t see the assignment of Rights
    #6472
    joeh6966
    I already wrote that I don’t understand the Rights tab.
    I just tried to open SCADA administrator to take a snip of the window for Rights, and SCADA will not even open now.
    I will have to uninstall and reinstall.
    I wrote today about four errors I found in https://forum.rapidscada.org/?topic=connecting-devices-using-modbus-protocol
    This program became unusable.
    #6475
    You just don’t know how to cook it 🙂
    <img src="<img src=”https://i.ibb.co/NxYkSrG/Rights.jpg&#8221; alt=”Rights” border=”0″ />” alt=”Rights tab” />
    #6477
    https://ibb.co/K6yQwD8
    #6484
    The default user Admin has full rights despite you fill the Rights table. Make sure that the view is opened if Admin is logged on.
    #6486
    joeh6966
    View is opened but there is nothing to see.
    I checked the Rights table, and the drop down menu has nothing to click on for Interface Object.
    https://ibb.co/Z1hqYqQ
    https://ibb.co/zGzVQKS
    #6488
    joeh6966
    I think that the requested view doesn’t exist, but I think that I selected the correct folder and file in the interface table. So, what next?
    #6489
    It is strange that you have selected a project in the Interface and not interface files.
    The Interface object must be created either in tabular form or in graphical form
    Interface-Create a Table file (or Scheme)
    Add the necessary input channels in a table view
    #6496
    joeh6966, you should define the views exactly as it’s shown in the videos. No *.rsproj files there.
    #6501
    joeh6966
    To Manjay73;
    I click on Interface and nothing happens except the + sign disappears. There is no right-click menu either that lists “Interface-Create a Table file (or Scheme)”.
    I’ll try to view the videos again to see how to do this.
    Already it is good enough even if I do nothing more, because I can stop monitoring the meter as SCADA records the readings in Archives.
