Forum Home › Forums › Installation Issues › SCADA-Web Installation › Installation of Webstation plugins
- This topic has 33 replies, 3 voices, and was last updated 6 years, 11 months ago by
January 17, 2019 at 2:17 am #4905
HoracioParticipantHello
I installed the Extra Scheme Components Plugin.
In Main menu – Installed – Plugins it said: “Plugin activated successfull.” and it is marked as “Active”.1. The vertical level does appear in the Scheme menu and allows me to include it in a Scheme but when I go to Webstation, it says:
“Registration failed for “Extra Scheme Components”.
No library found for component extra:Level.”
2. The horizontal level does not appear in the Components menu.
3. The gray gauge does appear in the Scheme menu but I can’t add it to a Scheme.
4. The colored gauge does not appear in the Components menu.I am using Windows 10, and Webstation 5.0.6.0.
Perhaps I mixed up while copying the files to the C:Scada directory.Your hints will be appreciated
January 17, 2019 at 2:10 pm #4906
Please check registration on http://localhost/Scada/plugins/Registration/Registration.aspx?prodCode=PlgSchExtraComp
January 17, 2019 at 6:14 pm #4910
HoracioParticipantThank you for reply.
After trial key was registrated I do not see anymore the message about “Registration failed”However I still have these problems:
1. The vertical level does appear in the Scheme Components menu and allows me to
include it in a Scheme but then in Webstation I only see a gray empty
rectangle.
2. The horizontal level does not appear in the Scheme Components menu.
Perhaps I mixed up while copying the files to the C:Scada directory.January 18, 2019 at 2:07 pm #4912
MikhailModeratorFirst of all, upgrade Webstation to 5.0.7.0 and Scheme Editor to 5.2.2.0.
1. Please check ScadaWeb.log for errors.
2. Horizontal or vertical depends on level width and height. Just resize it.
3. Provide more details about the issue.
4. Colorized gauge is the same component with background image. Background images can be found in the internet.January 18, 2019 at 7:51 pm #4915
HoracioParticipantThank you.
1. I can’t interpret the ScadaWeb.log nor know how to attach the file here.
3. I can choose the level component and put it in a Scheme but when I see it in Webstation I see just a white rectangle. Please see here:
http://hv-scada.dyndns.org:81/Scada use default login and password 12345
First scheme, lower right zone.January 20, 2019 at 1:21 pm #4921
MikhailModeratorFirst of all, upgrade Webstation to 5.0.7.0.
January 21, 2019 at 9:43 pm #4925
HoracioParticipantThank you!
Rapid Scada 5.0.6.0 installed.
Extra Schema Components working properly.January 22, 2019 at 2:35 pm #4929
MikhailModeratorRapid Scada 5.6.0 that includes Webstation to 5.0.7.0 ))
June 3, 2019 at 9:28 pm #5507
I upgraded Rapid Scada from 5.6.0 to 5.6.1 on a Win 10 PC.
Scheme Editor is 5.2.3.1
Then migrated the my old configuration to the new version on same server.
Everything works but the plugins I had before (permanent licence purchased. ExtraScheme Components, ChartPro, and Dashboard) do not work.
Then I followed the instructions on “Installation of Webstation Plugins”.
On Webstation the schemes do not open and it says: “Scheme loading failed. Try to reload Scheme”.
On Webstation – Main Menu – Plugins – Installed it says:
– PlgChartPro.dll
– PlgDashboard.dll
– PlgSchExtraComp.dllBellow each one of them it says “Deactivate” in blue.
To the right of each it says “NotLoaded” in redHow should I do to reactivate them?
June 4, 2019 at 12:35 pm #5511
You should also upgrade the plugins. Keys and settings are compatible.
After upgrading, press Ctrl+F5 in your browser to refresh the scripts.June 4, 2019 at 12:36 pm #5512
MikhailModeratorNote: There is a bug in saving files in Scheme Editor 5.2.3.0. You should take Scheme Editor 5.2.3.1 from Rapid SCADA 5.7.0.
June 5, 2019 at 2:05 pm #5516
HoracioParticipantHi Mikhail
Thank you very much for your support.
The Extra Scheme Components now appear on Webstation and do work but the Scheme Editor app. does not open.
I haven’t installed yet the Scheme Editor 5.2.3.1 from RS 5.7.0 as you indicated.Can I install just the Scheme Editor 5.2.3.1 over Rapid Scada 5.6.1? How?
Or should I install the whole 5.7.0? If yes, can I migrate my former configuration flawlessly to it?Regards
June 5, 2019 at 2:10 pm #5517
HoracioParticipantI mean, can I migrate to 5.7.0 with the current”Migrate Configuration” procedure?
June 5, 2019 at 3:58 pm #5518
MikhailModeratorOr should I install the whole 5.7.0?
This is better, because this is the future of Rapid SCADA.
Read this topic for migration details.Can I install just the Scheme Editor 5.2.3.1 over Rapid Scada 5.6.1? How?
Just replace the files of the editor.
This problem may not be caused by the app version.
June 5, 2019 at 6:29 pm #5521
HoracioParticipantThank you very much.
I replaced ScadaSchemeEditor files of 5.6.1 by the same files of 5.7.0
(ScadaSchemeEditor 5.2.3.1) and it works well.
Best regards -
