Forum Home › Forums › Understanding the Software › I have issue about database import (MYSQL)
- This topic has 19 replies, 4 voices, and was last updated 2 years ago by
September 9, 2024 at 5:57 pm #15351
joey
ParticipantMy project need to import data from mysql but we have a problem. If I fetch data from my database, communication log showed every thing fine no issue but in current data didn’t show anything. How to fix it, please help me. I’m stuck in this issue since last month. Appreciate sir.
September 10, 2024 at 9:47 am #15362
Please make a screenshot of a device data page in Communicator.September 10, 2024 at 11:50 am #15370joey
ParticipantSeptember 10, 2024 at 11:56 am #15371joey
ParticipantI’m not sure if this is the task you want. If you want more information please contact me again. Thank you so much.
September 10, 2024 at 11:59 am #15372
manjey73ParticipantThere is not a single channel on image1 that would read the Communicator, otherwise you would have a table with data in the Device 1 log of this type
[2] Energomera_301 ------------------ Драйвер : DrvIEC61107 6.2.0.5 Статус : норма Время сеанса : 10.09.2024 14:58:00 Время команды : не определено Сеансы (всего / ошибок) : 739 / 0 Команды (всего / ошибок) : 0 / 0 Запросы (всего / ошибок) : 9607 / 0 Текущие данные +-------+----------+-----------------+-----------------+---------+ | Номер | Код | Наименование | Значение | Канал | +-------+----------+-----------------+-----------------+---------+ | ****************** Счетчик Энергомера CE301 ****************** | +-------+----------+-----------------+-----------------+---------+ | 1 | serial | Serial # | 008841163127043 | 201-202 | +-------+----------+-----------------+-----------------+---------+ | 2 | V_L1 | Voltage L1 | 231,241 | 203 | +-------+----------+-----------------+-----------------+---------+ | 3 | V_L2 | Voltage L2 | 233,418 | 204 | +-------+----------+-----------------+-----------------+---------+ | 4 | V_L3 | Voltage L3 | 213,466 | 205 | +-------+----------+-----------------+-----------------+---------+ | 5 | Cur_L1 | Current L1 | 26,860 | 206 | +-------+----------+-----------------+-----------------+---------+September 10, 2024 at 12:14 pm #15373joey
ParticipantCan you explain, How to set channels so it can read the data in communicator
September 10, 2024 at 2:31 pm #15374
manjey73ParticipantFrankly, I do not know, I have never used this driver. You may have missed something in the settings or made them incorrectly.
September 10, 2024 at 5:31 pm #15375joey
ParticipantIs there a way for us to import a database from another driver?”
September 11, 2024 at 6:54 am #15379
manjey73ParticipantThere is another import driver from the database, but I don’t work with the database and I can’t tell how it works
September 11, 2024 at 7:36 am #15381joey
ParticipantI’ll try. Thank you so much.
September 11, 2024 at 9:06 am #15388
MikhailModeratorDon’t forget to specify tags for a query. One tag per line.
It’s in the device properties.-
This reply was modified 2 years, 1 month ago by
September 12, 2024 at 3:28 am #15402joey
ParticipantCan I have an example of what you mean? I think i fill only sql command. I think i forgot something. Thank you.
September 12, 2024 at 6:36 am #15411joey
ParticipantDo you mean the page in the image4 in the drive I shared? And what should I put in the tag?
This reply was modified 2 years ago by
joey.
September 12, 2024 at 7:41 am #15419joey
ParticipantAfter I added the tag, I now have the table, but the values still haven’t appeared.
September 12, 2024 at 9:37 am #15426
MikhailModeratorDo you mean the page in the image4 in the drive I shared? And what should I put in the tag?
Yes, image4.
Check this example https://ibb.co/ZMBdJBd -
