Forum Home › Forums › Installation Issues › SCADA-Web Installation › How to uninstall a rapid scada software in Raspberry Pi?
- This topic has 38 replies, 3 voices, and was last updated 5 years, 6 months ago by
April 14, 2021 at 7:10 am #8735
hethongscada62
ParticipantDear Mr.Mikhail,
I can not get the result with Chart Pro plugin. Maybe there was wrong something in somewhere. I will reinstall software on the same computer. It is OK when the keys still will be valid.
So Pls let me know how to uninstall Rapid Scada Software in Raspberry Pi?
Thanks and best regards
Han HoangApril 14, 2021 at 8:41 am #8736
manjey73ParticipantOn the same PC, the keys will work. Yes, just delete everything from the /opt/scada folder and that’s it. Strange, I have Chart Pro working without any complaints. Only my Raspberry Pi3 is too weak for this, 1GB is not enough for good work, you need to change the swap file system to another one.
April 14, 2021 at 9:40 am #8737hethongscada62
ParticipantDear manjey73,
Yes, i don’t know why. All keys are working well except ChartPro key. Can not save configuration.
You said “you need to change the swap file system to another one.” Could you tell more detail: What is swap file? Where is it locate?
Thanks a lotApril 14, 2021 at 9:56 am #8738
manjey73ParticipantUse the online translator or search for topics on zram on other resources.
Try this recipe to save the configuration
This reply was modified 5 years, 6 months ago by
manjey73.
April 14, 2021 at 12:10 pm #8740hethongscada62
The some were changed, after save configuration of Chart Pro i have had likes this:
“Error saving web application settings: Access to the path is denied.”
Some where is wrong?
Thanks a lotApril 14, 2021 at 1:07 pm #8741
manjey73ParticipantI can’t say, in theory, everything is related to the rights to the configuration file, after it is changed by the root user, the rights belong only to him. You can connect via SSH and give the command
chmod -R ugo+rw /opt/scada/ScadaWeb/configand then try to save the WEB configuration ?
April 14, 2021 at 1:49 pm #8744
The uninstallation instruction is in the package ZIP.
But I recommend not to uninstall Rapid SCADA, because you just need to fix file access rights. If you have issues with changing file access rights, post the related screenshots on the forum.April 15, 2021 at 12:58 am #8750hethongscada62
Dear Mr.Mikhail,
Thank manjey73 for your advice. I was tried by your method but can not get a result.
Thank Mr.Mikhail for your reply. I have had the uninstallation in ZIP. Of cause i don’t like to uninstall Rapid SCADA because my project is running perfectly on Windows, all it’s components are running well on Raspberry Pi4 except Chart Pro Plugin.
I don’t know where and how to fix file access rights. For example: “Error saving web application settings: Access to the path is denied.”
https://ibb.co/KbSfmr5
Thanks and best regardsApril 15, 2021 at 1:28 am #8751hethongscada62
ParticipantDear All,
Web application setting was configured likes this:
https://ibb.co/HrLnCSj
Where have i to fix?
ThanksApril 15, 2021 at 8:02 am #8755
manjey73ParticipantDid you connect to the Raspberry Pi4 via SSH, enter the specified command and it didn’t work? I have this command written in the server startup file and it is executed every time the server is restarted, since without it, access is also blocked after the first application.
April 15, 2021 at 10:38 am #8756hethongscada62
Yes, i connected to Raspberry Pi4 via SSH.
https://ibb.co/VtdrQbP
The specified command was entered likes this:
https://ibb.co/TLNdm0P
It did not work, namjey73
Where is wrong?
Thanks a lotApril 15, 2021 at 11:29 am #8757
MikhailModeratorHi everybody,
I would use PuTTY for remote command line.April 15, 2021 at 11:43 am #8761hethongscada62
The PuTTY was using. It is working, but operation not permitted.
https://ibb.co/L5P5QLC
Why????
ThanksApril 15, 2021 at 12:01 pm #8762
manjey73Participantsudo chmod -R ugo+rw /opt/scada/ScadaWeb/configThis command was used because you used sudo. After this command, open WEB Scada and try to change the configuration.
April 15, 2021 at 1:43 pm #8763hethongscada62
ParticipantDear namjey73,
It did not work. Strange. When i replaced access rights of Chart Pro by access rights of Chart, the project is running normally. It processes the Charts for me.
https://ibb.co/X5ppGS4
Maybe are somethings wrong in the Chart Pro file?
I don’t understand.
Thanks -
