Elastic Report Flexibility
Forum Home › Forums › Understanding the Software › Elastic Report Flexibility
Viewing 15 posts - 1 through 15 (of 30 total)
  • #3896
    jacklondon
    Hi Mikhail,
    i need different reports based on hours, shift (working) hours, daily, weekly, monthly… and any kind of time period.
    Is “Elastic Report” able to define the report time period, i.e. for an 8-hours shift period?
    regards
    #3898
    bencyau
    Same questions here on Elastic Report. Would like to be able to draw data from minutes and hourly data archive to report on hourly computations, and also for work shifts such as OEE reports (uses at least 3 channels of data).
    The ElasticReportExample uses hourly data from 12pm, not sure how to extend that into one or multiple shifts. Also the use of formula in Excel format does not show how to reference values from related channels at the same timeslot.
    Thanks.
    #3900
    Could you provide an example of a required report?
    #3902
    jacklondon
    Hi Mikhail, for example:
    One needs to report different energy consumptions for every shift between 00:00-08:00, 08:00-16:00 and 16:00-24:00, additionally hourly, daily, weekly, monthly…
    How to achieve that?
    Regards
    #3908
    Currently, possible values of the detailing parameter: Hour, Day, Month, BeginEnd.
    It means that you can get consumption between every hour, every day, every month or between the beginning and the end of the selected period.
    To support custom time period and weekly period, the Elastic Report plugin should be updated.
    Elastic Report uses hourly data. If you need minute data, please provide examples.
    #3921
    jacklondon
    … or between the beginning and the end of the selected period.
    Could be an alternative solution, if we could enter not only the date, but also concrete beginning and ending time (hours) when we let create the report at the elastic report page… For example: Same day, but only the beginning and ending times differ!?
    • This reply was modified 8 years, 4 months ago by jacklondon.
    #3931
    It requires an update of the plugin. We can discuss such development.
    The solution that can be implemented using the current plugin version: use Excel formulas to calculate consumption for needed ranges of time. I mean you get a report with hour detailing and Excel refers to the specified cells and calculates required values.
    #3968
    jacklondon
    Hi Mikhail,
    i think it would be enough for the beginning, to have also a range definition for hours (begin and end) additionally to date range at the page where we call an elasticreport, if possible!?
    That way we could give the same date as begin/end and then define the hour range for example for shift begin and end.
    Regards
    #3970
    Could you send me an email to this address? I will estimate a cost of the update and answer by email.
    #4970
    pitch26
    How to set the elastic report to show the maximum value attained for the day of a channel?
    #4973
    You need an input channel that stores max. value of each day. Than use this channel in your report configuration file.
    #7533
    dinop
    I am new with Rapid scada and scada in common.
    I am trying to figure out how does an Elastic report work.
    Inside the program I opened a new Interface with .xml
    Can someone give me an example of how to make a report for a daily/ shift consumption of energy for example. What to write inside the interface I opened, it begins with
    <?xml version=”1.0″ encoding=”UTF-8″ ?>. #
    What should I declare as input? Please some help with a pdf or some document that will make me understand how this works.
    Thanks.
    #7539
    The report example is included in plg_elastic_report_XXXX_en.zip. The file name is ElasticRepExample.xml. You should put it in the project, make settings according to the manual, and try to run.
    • This reply was modified 5 years, 11 months ago by Mikhail.
    #7676
    dinop
    I need report based on hours, shift (working) hours, daily, weekly, monthly… and any kind of time period.
    Is it possible to define report time period for 8-hour shift with ElasticReport?
    #7682
    Please provide the report example.
    Elastic Report allows to set a reading hour.
