Database SQL usage
Forum Home Forums Development and Integration Database SQL usage
Viewing 15 posts - 1 through 15 (of 19 total)
  • #9007
    Han
    I have a question about SQL.
    “INSERT INTO dbo.PN1 (triggertime,iiot_PN1_A1,iiot_PN1_A2,iiot_PN1_A3,iiot_PN1_A4)
    VALUES ( , , , , );” How to associate the value of the variable?
    Are there any system default variables? Similar to the system time, it can be used directly.
    • This topic was modified 5 years, 2 months ago by Han.
    #9013
    What module of Rapid SCADA do you use to execute this SQL request?
    What DBMS type?
    #9016
    Han
    Microsoft SQL Server,KpDbImport,thank you !
    #9020
    Microsoft SQL Server definitely provides a current time function. You should google it on database forums.
    If you use KpDbImport for sending commands, it supports @cmdVal and @cmdNum parameters of the SQL statement for command value and command number.
    What is the generalized task you need to resolve?
    #9021
    There is also ModDbExport module. You should compare it with KpDbImport.
    #9025
    Han
    Sorry, I am a novice, can you provide the usage of @cmdVal and @cmdNum. I want to write the value read by modbus into SQL, for example, write the value of channel 101 of modbus into SQL?
    • This reply was modified 5 years, 2 months ago by Han.
    #9027
    Han
    Something like
    insert into mytable field1 values (@cmdVal)
    A command contains only one value.
    You should try. In case of errors, you could send links to screenshots and post logs.
    #9100
    Han
    Microsoft SQL Server,KpDbImport or ModDBExport;Could you provide the following example ?Thank U
    #9102
    Perform the settings according to the manual. In case of errors provide screenshots of the settings and error messages.
    #9127
    Han
    2021-06-22 22:32:13 Establish a TCP connection with :1433
    2021-06-22 22:32:13 Communication session with the Device 2 “SQL2008”, type: KpDbImport
    Data request
    Error executing query: scalar variable “@CnlNum” must be declared.
    Data request
    Data request
    Data request
    #9128
    Han
    How to declare variables?
    #9133
    Variable names are case sensitive. Just copy them from the manual.
    #9140
    Han
    Hi,Mikhail
    Thank you for your help all the time.
    Sorry, I failed to describe my needs clearly before. I want to write the data (data1, data2, data3…) obtained by Modbus into the SQL table at a frequency of once a minute. The columns of the SQL table are arranged in accordance with the (writing time, data1, data2, data3… ).Retrieving data from Modbus has been successful. But I don’t know how to write SQL in the above arrangement.
    #9141
    Han
    I’m sorry, my English is poor, and I don’t know if the grammar I described is correct. I use Google Translate.
