Custom Page
Viewing 15 posts - 1 through 15 (of 24 total)
  • #8371
    Matt3
    Hi
    I’m looking to add channel values to a custom web page.
    I’ve used the files in this link as my starting example…
    https://github.com/RapidScada/scada-community/tree/master/Plugins/CustomPageExample
    How do you suggest reading multiple current values, say from channels 101, 102 and 105 of the hello World example?
    Matt
    #8376
    Use getCurCnlDataExt function. If you run file search of “getCurCnlDataExt” on *.js files, you will find examples in the Table and Scheme plugins.
    #10368
    csshenrapid
    Why can’t the page load all the time?About CustomPageExample.
    #10371
    Could you explain your question?
    #10678
    ramiouba
    I have RapidScada v5.8.4 installed and everything is working fine on my windows PC, I deployed the custom pages example exactly as mentioned in the following link https://github.com/RapidScada/scada-community/tree/master/Plugins/CustomPageExample
    But when I uploaded the “HelloWorld” project and re-logged into the SCADA and select the desired page nothing appeared, and the animated loading progress sign still rotating without any changes. I thing something is missing in the configuration, or the location of custom pages folder is not correct.
    Could you please help me to fix this issue?
    Thanks,
    Rami
    • This reply was modified 4 years, 1 month ago by ramiouba.
    #10685
    Hi Rami,
    In browser press F12, select the Console tab and check the web page errors.
    Screenshots of configuration and error would help.
    • This reply was modified 4 years, 1 month ago by Mikhail.
    #10700
    ramiouba
    Hi Mikhail,
    I checked the errors in browser’s console then I found the error that causes this issue.
    It was because I’ve defined a full path of the “myPage.html” file starting with “C:\SCADA\bla\bla\bla\myPage.html” in the interface database of the Scada Administrator, the browser console return an error that “the server can’t access local resources” where the file is located.
    I’ve changed the path to the one that mentioned in the example of “Custom Pages”, I paste it as it is “../../custom/MyPage.html” then it worked correctly.
    Thanks for your help Mikhail.
    Rami
    #10710
    Good 🙂
    #12206
    Matt3
    Hi Mikhail
    I’m starting to use v6 for live projects.
    I need to add a custom page showing 5 tag values. I modified the code in v5 to read channel data.
    Can you please provide script showing the best way to continuously read the values form from 5 channels and to show the value on the page.
    Thank you
    Matt
    #12225
    Custom web page example for v6 has not been developed. You should use main-api.js to get data from a web page.
    #12495
    Matt3
    Hi Mikhail
    We are using version 5.8.4 with 24 custom pages, in a production environment.
    We tried to port some of our pages to version 6.1.1 but failed, so we tried a very basic html page but failed there too. I can see the menu item “TEST” in the left hand menu but when I hover the mouse pointer over it, it changes to a “no entry” icon (red circle) so we cannot click the link.
    We are using the Hello World sample project and adding the custom page to item 3 in the list. I’ve been in to the browser view source option. I’ve added the source code below…
    1 – In version 6, if I have a file named Test.html, where should I save it (where is the custom folder located)?
    2 – and what path structure should I use when I enter the path, via ScadaAdmin, in the “view” section.
    Matt
    <div class='node-parts'><div class='indent'></div><div class='expander left empty'></div><div class='icon'></div><div class='text'>Simulator</div></div>
    <div class='node-parts'><div class='indent'></div><div class='expander left empty'></div><div class='icon'></div><div class='text'>TEST</div></div>
    • This reply was modified 3 years, 5 months ago by Mikhail.
    #12501
    Hi Matt,
    1. SCADA\ScadaWeb\wwwroot\custom would be good.
    2. In the Views table set
    Path = (any)
    View Type = Web page view
    Arguments = ../custom/mypage.html (may be it’s not correct, but we need to start from somewhere)
    Title = (any)
    #12507
    Matt3
    Hi Mikhail
    Thank you for your feedback.
    By moving the custom folder under wwwroot, I can show htm pages.
    Path
    ../../custom/Page1.htm
    Arguments
    View Type
    WebPageView
    Title
    \Page1
    However, when I copy default.aspx page, it is not shown? Are aspx pages not supported?
    Kind regards
    Matt
    #12510
    *.aspx is an old ASP.NET extension. Webstation 6 uses Razor Pages for development.
    #12515
    Matt3
    Hi Mikhail
    Aha!!!
    It makes sense now. I’ve started learning razor pages.
    Is it possible to have a few example pages showing how to add a custom page (an example sowing how to get 5 or more channel values would be perfect).
    Matt
