Forum Home › Forums › Runtime Bugs › Current Data sudden become Not Ready
- This topic has 20 replies, 2 voices, and was last updated 2 years, 6 months ago by
February 16, 2024 at 2:33 am #14063
kcks66
ParticipantHi Mikhail,
I am using v6. As per topic, some of my calculated data sudden became — while Real data and other calculated data all OK.
I click Upload button and the Current Data become Ready back. Those — calculated data also got reading back.
As you can see one of the — calculated data has no data in the graph below.
Somehow there is data stored in PostgreSQL below.
Need your advice to avoid this incident from happen in the future.
Thank you.February 16, 2024 at 11:08 am #14064
Could you provide the screenshot of the archive configuration and archive log file?February 17, 2024 at 5:44 am #14065kcks66
My archive configuration screenshot as below.
But I have no idea where to get the archive log file.
This reply was modified 2 years, 7 months ago by
kcks66.
February 19, 2024 at 9:56 am #14071
Archive configuration is displayed when you open its properties.
Log files are located in SCADA\ScadaServer\Log directory. You should enable the detailed log in the archive properties.February 21, 2024 at 1:37 pm #14079kcks66
I just enable the Current Data’s detailed log. Rigth now I just wait for next Current Data suddenly become Not Ready again in the future, right?
February 22, 2024 at 9:05 am #14081
MikhailModeratorOK. Save log files in case of error.
March 14, 2024 at 1:24 am #14206kcks66
The same error happened again:
This round I managed to capture the error log:
2024-03-13 22:27:04 Enqueueing of 1401 data points completed successfully in 0 ms
2024-03-13 22:27:04 Data queue has become empty
2024-03-13 22:27:30 Enqueueing of 1401 data points completed successfully in 0 ms
2024-03-13 22:27:31 Error writing to database:
Npgsql.PostgresException (0x80004005): 57P03: the database system is shutting down
at Npgsql.Internal.NpgsqlConnector.<ReadMessage>g__ReadMessageLong|223_0(NpgsqlConnector connector, Boolean async, DataRowLoadingMode dataRowLoadingMode, Boolean readingNotifications, Boolean isReadingPrependedMessage)
at Npgsql.Internal.NpgsqlConnector.Authenticate(String username, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.Internal.NpgsqlConnector.<Open>g__OpenCore|203_1(NpgsqlConnector conn, SslMode sslMode, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken, Boolean isFirstAttempt)
at Npgsql.Internal.NpgsqlConnector.Open(NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.ConnectorPool.OpenNewConnector(NpgsqlConnection conn, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.ConnectorPool.<Get>g__RentAsync|28_0(NpgsqlConnection conn, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlConnection.<Open>g__OpenAsync|45_0(Boolean async, CancellationToken cancellationToken)
at Npgsql.NpgsqlConnection.Open()
at Scada.Server.Modules.ModArcPostgreSql.Logic.PointQueue.ProcessItems()
Exception data:
Severity: FATAL
SqlState: 57P03
MessageText: the database system is shutting down
File: postmaster.c
Line: 2353
Routine: ProcessStartupPacket
2024-03-14 08:24:35 Reading of 1401 data points completed successfully in 81 ms
2024-03-14 08:24:35 Enqueueing of 1401 data points completed successfully in 0 ms
2024-03-14 08:24:36 Data queue has become empty
2024-03-14 08:25:00 Enqueueing of 1401 data points completed successfully in 0 ms
2024-03-14 08:25:00 Data queue has become emptyI reupload again then the Achieve all became Ready back. Pls advice for what should I do to avoid this from happened again.
March 14, 2024 at 5:09 am #14211
You can see that the error isNpgsql.PostgresException (0x80004005): 57P03: the database system is shutting down
You should check the PostgreSQL database. When it is not available from SCADA, try to connect to it by pgAdmin.
March 14, 2024 at 11:52 am #14214kcks66
1) I couldn’t understand why PostgreSQL database suddenly shutting down?
2) The Rapid SCADA’s Archive became READY back after I clicked the Rapid SCADA upload button. Pls advice the error is came from Rapid SCADA side or PostgreSQL database side?By the way, where should I check at PostgreSQL database/pgAdmin to search for error?
Thank you.March 15, 2024 at 5:00 am #14220
1) The error is weird. It’s the first time when we faced this type of error.
What PostreSQL version do you use?2) Probably, it just reconnects. The next time, if the error occurs, try stop and start SCADA-Serve without uploading the project.
Using pgAdmin simply try to connect to the database and open the data tables after the error occurs.March 15, 2024 at 5:02 am #14221
MikhailModeratorMay be the error occurs after the computer restart? And PostgreSQL has not started yet?
March 15, 2024 at 6:30 am #14222kcks66
1) I am using PostgreSQL 16.
2) Noted. I will stop and start SCADA-Serve without uploading the project, and use pgAdmin to check database if the error occurs again.
FYI, the computer is left 24/7 without shutting down. I also enable MinCopy by using ModArcBasic just in case happen in the future I can cross check.
March 16, 2024 at 3:06 am #14225kcks66
I managed to installed PC On/Off Monitor software into the PC and I found there was a PC shutdown exactly at that time. Kindly see below for the findings:
I think the PC restart is because there is Windows Update activities historical record found on 13/3.
I believe we found the cause to make Rapid SCADA Archive suddenly became Not Ready. Pls advice for what setting should I do to make the Rapid SCADA or PostgreSQL to resume the data storing process after PC restart/resume?
March 16, 2024 at 3:47 am #14228
It seems that we are close to understanding the cause.
If you restart the PC in usual way, do you get the same error?March 20, 2024 at 6:53 am #14238kcks66
Today the PC experienced power supply tripped. The Rapid SCADA Archive became Not Ready after PC auto restart when power supply resumed. However the MinCopy Achieve is Ready.
This round I stop and start SCADA-Serve without uploading the project. The Rapid SCADA Archive became Ready back.
I use pgAdmin to connect to the database and open the data tables during Rapid SCADA Archive Not Ready, it just blank.
Look’s like the Rapid SCADA Archive always become Not Ready if PC experienced shutdown and resume back, for Archive setup using PostgreSQL as main database.
Pls advice for the counter measure can be taken to avoid this incident from happened again in the future.
