Input channels and Output channels
Forum Home › Forums › Understanding the Software › Input channels and Output channels
Viewing 2 posts - 1 through 2 (of 2 total)
  • #11656
    victorlam
    Hello,
    I checked with the documentation.
    Input channels mean all the registers values to be retrieved and linked with the signal number.
    Output channels mean all the command proposed and linked with the command number.
    Then my questions is :-
    Can the number of input channels need to equal to the number of output channels?
    Or quantity of output channel(s) is larger than the quantity of input channels?
    Also, all the input channel and output channel numbers are arbitrary value. User must need to check the channel signal or command number defined by the device.xml. Correct me if my interpretation is wrong.
    #11666
    Hello,
    Amount of input and output channels may be equal or not equal, depending on the needs.
    If an output channel is used for changing the input channel, I recommend to use the same IDs for them. It is important to transfer project to v6 later.
