Reading Day in Elastic Report
Forum Home › Forums › Understanding the Software › Reading Day in Elastic Report
Viewing 15 posts - 1 through 15 (of 18 total)
  • #10468
    Hari
    Can you explain, what will happen if we change Reading Day to 1 or any other value in elastic report?
    This is the example code in Elastic Report xml file.
    <!– Day of monthly meter readings –>
    <ReadingDay>20</ReadingDay>
    • This topic was modified 4 years, 2 months ago by Mikhail.
    #10470
    In the example configuration file ElasticRepExample.xml all parameters have descriptions.
    ReadingDay – Day of monthly meter readings
    It means that this is a day of month that is used to get values if report argument is a month without specific date. For example, if report period is from April to May, the actual data period would be from April 20 to May 20.
    #10471
    Hari
    Thanks Mikhail.
    And how to set time range (Reading Hour) for getting single day data. For Eg, I need data for 00:00 to 23:00 for a particular day.
    #10472
    Set ReadingHour to 0.
    Select the same start and end dates in the report parameters form.
    #10473
    Hari
    If I set reading hour to 0 I’m getting data for next day 00hrs also. I have selected Same start and end dates in reports.
    Elastic Report
    I need data for that particular day alone.
    • This reply was modified 4 years, 2 months ago by Hari.
    #10476
    The link does not work. Please provide public access for the link.
    #10477
    Hari
    Could you try to set SkipFirstHour parameter of the section to true?
    Then publish a screenshot with SkipFirstHour=true
    #10483
    Hari
    I have set SkipFirstHour = true. But still it is showing like that.
    Report
    #10484
    Thank you for the screenshot.
    To solve the issue, a new parameter SkipLastHour should be implemented for the plugin. I’ve added it to the list of features to implement.
    #10486
    Hari
    Thanks Mikhail.
    #10488
    Hari
    Is there any attributes for calculating standard deviation like we have calcAvg to calculate Average?
    #10491
    If you export reports in Excel format, you could use Excel formulas.
    In case of using PFD, there are average, sum, min and max functions available.
    #10492
    Hari
    We can directly type formulas in that xml file or we have to do calculations only in excel after exporting?
    #10562
    victorlam
    I see that there is “average” column inside the input channel description table? May I know what is the meaning of average here? Not sure why there is average for one channel number value?
