Forum Home › Forums › Understanding the Software › Problem with data adquisition
- This topic has 23 replies, 2 voices, and was last updated 3 years, 4 months ago by
May 10, 2023 at 10:18 am #12554
feltduck
I want to know if there is any way to be able to read the records from x days ago. when I have a cut instead of filling in the gap with the corresponding time
fills it with the consumption of the current hour.For example:
I have a power cut at 9:15 and it is restored at 15:00,the scada instead of consulting the data from 9:15 onwards and filling in the empty hours, takes
the current data and continues as if the data occurred at 9:30.May 11, 2023 at 10:50 am #12561
Usually when controller is not available, the Communicator app sets data to undefined. If you provide screenshots of the settings and data, we could provide additional thoughts about that.
May 12, 2023 at 6:57 am #12569feltduck
ParticipantWhich settings do you want to see?
May 12, 2023 at 11:26 am #12573
MikhailModeratorCommunicator settings, channels, user interface.
May 17, 2023 at 8:20 am #12623feltduck
ParticipantHi, sorry for the delay.
These are the communicator settings:
https://tinypic.host/i/ohOeKkAnd these the channels:
https://tinypic.host/i/ohOcsDI’m not using an user interface.
May 17, 2023 at 9:43 am #12625
Also a screenshot of the device data form (from Communicator) is needed.May 17, 2023 at 10:01 am #12627feltduck
ParticipantHere it is:
https://tinypic.host/i/ohOmh4May 18, 2023 at 10:46 am #12638
MikhailModeratorProbably, you need to change connection mode to individual and set IP address to the device properties if you don’t use an intermediate gate device between the PLC and PC.
This reply was modified 3 years, 4 months ago by
May 18, 2023 at 11:15 am #12645
MikhailModeratorIf device communication was OK, and then the device become unavailable, the device data in Communicator should be changed to
---. If not, let me know and provide communication line log.May 19, 2023 at 10:19 am #12650feltduck
ParticipantI need to set the connection on shared because I’m working with more than 1 device.
The communication is working well but when the SCADA stores the data in the BBDD it has a problem with the datetime.
E.g:
In this screenshot the datetime is at 10:00 when the real time is 12:15.
https://tinypic.host/i/ohzhpAThen at 12:30 it’ll store the data with the datetime at 10:15 in the BBDD.
May 19, 2023 at 2:58 pm #12653
MikhailModeratorCould you tell what is “BBDD”?
What is the time zone?May 22, 2023 at 6:33 am #12668feltduck
ParticipantI’m sorry, BBDD it’s the acronym for data base on my language.
My timezone is Madrid GMT+2May 22, 2023 at 7:31 am #12670
MikhailModeratorIn Rapid SCADA all data uses UTC timestamps. Some databases (like PostgreSQL) have special data type to work with timezone, some databases don’t have such data type.
If actual timestamps always differs by timezone offset, it’s OK and can be corrected in the SQL request.May 22, 2023 at 7:33 am #12671
MikhailModeratorAlso check in log files that data queues of the module do not overflow.
May 22, 2023 at 8:11 am #12675feltduck
ParticipantOk, thanks for the information. The other question that I have is when a device get disconnected the data is stored like this:
https://tinypic.host/i/oW7LIq
I want to check the data that is stored in the device at that hour and replace it. -
