Numbers can not be seen in the table.
Forum Home › Forums › Understanding the Software › Numbers can not be seen in the table.
Viewing 15 posts - 1 through 15 (of 18 total)
  • #2032
    phachakorn
    Hi
    I use RAPID V.5.1.1 after installation. I can see current value in table is normal but ,Hour numbers can not be seen in the table.
    Please suggest a correction.
    I use WIN 7 Pro.
    TABLE
    thanks you
    • This topic was modified 9 years, 8 months ago by phachakorn.
    #2035
    The hour columns will be filled when the software works at least a hour.
    #2037
    phachakorn
    Hi Mikhail
    Thanks for the quick answer.
    But my software has run for 48 hours ago.
    And now I have not seen any numbers in hour columns.
    Please how to fix
    thanks you
    • This reply was modified 9 years, 8 months ago by phachakorn.
    #2042
    It’s a bit unusual. Go to the Server app, open Files > Hourly data and check whether raw hourly data exist or not. Also check Saving parameters of Server.
    We can quickly solve the issue via remote connection, but it is a commercial service.
    #2044
    phachakorn
    Hi Mikhail
    I checked It has a raw hourly data exist.
    But there is the inaccuracy of the number of years.
    Look at the picture.
    hourly data file
    data file
    Please how to fix
    thanks you
    #2048
    Please make a screenshot of a whole list of the files which contains hourly data.
    #2050
    phachakorn
    hourly file
    #2052
    File name is a date YYMMDD. It’s strange that the files were created like your current year is 1960.
    Could you see Minute Data, are the files also have names like m60xxxx.dat?
    Please post here a content of C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt
    #2053
    phachakorn
    HI
    mine
    2560-03-27 15:46:18 <SCADA-PC><SYSTEM><ACT> ScadaServerService 5.0.1.0 is started
    2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 40
    2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Ouput channels are read from the configuration database
    2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Users are read from the configuration database
    2560-03-27 15:46:20 <SCADA-PC><SYSTEM><ACT> Formulas are read from the configuration database
    2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> The formulas source code has been compiled
    2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Connection listener is started
    2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Start server
    2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Current data are not loaded
    2560-03-27 15:46:32 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-27 15:46:32 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2560-03-27 22:28:32 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-27 22:28:32 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
    2560-03-27 22:29:27 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
    2560-03-27 22:30:57 <SCADA-PC><SYSTEM><ACT> Disconnect client 127.0.0.1
    2560-03-27 22:38:02 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-27 22:38:02 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> Connection listener is stopped
    2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> Server is stopped
    2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> ScadaServerService is stopped
    2560-03-27 22:38:40 <SCADA-PC><SYSTEM><ACT> ScadaServerService 5.0.1.0 is started
    2560-03-27 22:38:40 <SCADA-PC><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 40
    2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Ouput channels are read from the configuration database
    2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Users are read from the configuration database
    2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Formulas are read from the configuration database
    2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> The formulas source code has been compiled
    2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Connection listener is started
    2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Start server
    2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Current data are loaded
    2560-03-27 22:38:50 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-27 22:38:50 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
    2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
    2560-03-27 22:42:35 <SCADA-PC><SYSTEM><ACT> Disconnect client 127.0.0.1
    2560-03-28 18:57:25 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
    2560-03-28 18:57:25 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
    2560-03-28 18:57:34 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
    #2054
    Such a funny bug. Do you have any idea why the current year for the user system is 2560?
    Please, see C:\SCADA\ScadaComm\Log\ScadaCommSvc.log Is there 2560 year too?
    The applications that have graphical user interface work as your logged in user, whereas Server and Communicator services work as system.
    Try opening Control Panel > Administrative Tools > Services and changing the user for ScadaServerService and ScadaCommService
    #2055
    phachakorn
    Hi
    In Thailand, there are two year count systems.
    Buddhist era and Christian era.
    2560 is Buddhist era count systems.
    But in computer i setup Legion and Language format to Christian era.
    Do I need to set up another one?
    I see C:\SCADA\ScadaComm\Log\ScadaCommSvc.log have 2560 year too.
    I will try to follow this advice.
    “Try opening Control Panel > Administrative Tools > Services and changing the user for ScadaServerService and ScadaCommService”
    thanks you
    #2062
    Very interesting information. Thank you.
    I think, the most simple way is changing user for ScadaServerService and ScadaCommService. Pay attention, that the user must be PC administrator.
    #2066
    phachakorn
    hi
    I do as you suggest. It gives the Hourly file a valid year name (170331.dat) . And in the log file, the year number is 2017.
    But in the table on the web SCADA that do not have the numbers.
    Do I have to fix anything else?
    #2067
    First of all, check the existence of data in the file h170331.dat using Server user interface as you did earlier.
    #2098
    phachakorn
    hi
    i checked all number of year is 2017 all data but number in WEB table view not show.
