Map code
Viewing 15 posts - 1 through 15 (of 16 total)
  • #11676
    dannytan
    I have 2 questions regarding the map.
    I have already put my input from my modbus (decimal) into 101 channel.
    Now i would like to show
    Status : Normal if 1; Fire 1 if 2 ; Fire 2 if 3
    How can i write this function inside the map
    Second questions,
    I would like to put my map’s pin became green if Normal (1) and Red (if not 1)
    • This topic was modified 3 years, 10 months ago by dannytan.
    #11678
    dannytan
    I make a new unit called State (ID 38) Normal;Fire1;Fire2
    No matter what decimal i got from the input (0,1 or 2); the state stucked on Normal state.
    #11679
    dannytan
    Hi again,
    The first question settled ; i have changed input into enum text, everything is fine now. Can you help me with the color state of the pin on the map plugin ?
    #11682
    According to the manual: “0 – channel not specified; positive channel value means the location is normal, otherwise the location needs attention”.
    So channel formula might be: Cnl <= 1 ? 1 : -1
    #11683
    Probably, you should create a new channel of the calculated type with the formula
    Val(101) <= 1 ? 1 : -1; Stat(101)
    where 101 is the source channel number
    #11686
    dannytan
    Hi Mikhail,
    Thanks for your promp reply. I checked .map file. But it doesnt specify on how to associate my chanel input into the pin on the map.
    I would like my 101 input to be associate with the map pin and show let say green on 0 and red on 1 . How am i supposed to do it?
    https://wetransfer.com/downloads/b6a93d6b165f9e061f15618f6bbb84b320221125092743/94674ccc32b4f7537b413c7a48d12e3520221125092803/98331d
    #11687
    Unfortunately, wetransfer.com does not work in Russia, so I can’t check the file.
    Please upload the file to another file hosting.
    #11689
    dannytan
    Hi Mikhail,
    I know the problem now, it is on <StatusCnlNum>, problem is that if my decimal input = 0 ; My map pin turns green and if it is positive ; my pin turns grey
    How to turn the map pin to green if >0 and turns red if 0
    Secondly,
    For the link details as for now <link viewID = “2”/>
    How to change this link into my power BI link? let say “https://powerbi.com&#8221;
    #11690
    dannytan
    Hi Mikhail,
    Sorry again, i have found the solution by simply copy paste the website link into the interface and it works.
    Now , my question will be
    “problem is that if my decimal input = 0 ; My map pin turns green and if it is positive ; my pin turns grey
    How to turn the map pin to green if >0 and turns red if 0”
    #11691
    Use a channel formula mentioned above or similar.
    #11693
    dannytan
    Hi Mikhail,
    Yeah i understand, problem is that what is the input so that the pin is red? or grey or blue?
    #11696
    It should be a channel that displays location status. For example, some tag of a device mounted on the site.
    #11727
    dannytan
    Hi Mikhail,
    Sorry i am having difficulty in this map.
    So my input channels is 125 with signal 25 (from modbus with value of 0)
    I make another input 101 with channel type real ; object enterprise; device state ; signal (blank) ; formula used (check) ; Formula Val (125) <=1 ? 1 : -1 ; Stat (125)
    Then in .map file i put “<StatusCnlNum> 101 </StatusCnlNum>”
    The pin won’t turn red.
    I want the map pin to turn red if 125 with signal 25 (modbus is 0) , green (otherwise).
    Thanks a lot.
    #11730
    Before binding the channels to a map, I suggest to display the channels on a table view to check their values.
    Please provide screenshots of the channel properties and a screenshot of a table view containing channel values.
    #11740
    dannytan
    Hi Mikhail,
    It works now with this Cnl <= 1 ? 1 : -1
    So my channel input is 101 (with data value of 0) , when i put this formula, it became 1 and pin map turns RED
    Question now is how to make the pin map turns green if data value is bigger than 0?
    I wrote a formula in my dictionaries
    ID 11 :
    if (Cnl<1)
    { return 1; }
    else
    {return 0;}
    Another question is how to put this formula ID into my formula table in the input channels?
