Log in web page
Forum Home › Forums › Understanding the Software › Log in web page
Viewing 15 posts - 1 through 15 (of 23 total)
  • #5496
    scadarapid
    Hi.
    If I do not want to log in web page.
    How can I do.
    Thank you so much.
    #5499
    Do you mean to log in automatically?
    #5500
    scadarapid
    Hi.
    Yes
    Thank you so much
    #5501
    scadarapid
    Log in without fill user and password.
    How can I do.
    Thank you so much.
    #5502
    Try this plugin.
    It logs in as the first user in the Users table.
    #5503
    Use this link to open your web app:
    http://localhost/Scada/AutoLogin.aspx
    #5626
    scadarapid
    Hi.
    Could you tell me the step how to use please.
    Thank you so much.
    #5628
    gasin
    i try to do as your mention. after that i found error occur on screen. it show message error to update scheme data and i see all graphic did not show value.
    it’s look like graphic can not connect to database.
    how can i solve it?
    #5698
    Please provide a screenshot.
    #5718
    scadarapid
    Hi.
    I tried the PlgAutologin but it did not work now.
    I have noticed that when I change the file name Web.config in the ScadaWeb(I copy from PlgAutologin folder and directly put it on the ScadaWeb folder) then, It made (Error updating current data Error, updating hourly data)
    I have noticed the file Web.config of PlgAutoLogin and normal Web.config are different.
    so How we solve the Error Updating data on the scheme.
    when I use the web.config of PlgAutoLogin. I got this error.
    https://www.img.live/images/2019/07/17/150215.jpg
    https://www.img.live/images/2019/07/17/150214.jpg
    Thank you so much.
    #5722
    gasin
    now, i’ve problem with autologin,too.
    before i add autologin to scadaweb folder, everything work fine.
    after i add autologin to scadaweb folder and try to access website via address http://localhost/scada/login.aspx , i can pass login padge but it show error like this
    https://1drv.ms/u/s!Ah3lJWvSyxVOgvcCAlGYfk_y6Xc4IA
    and when i try to access website to be autologin like this http://localhost/scada/autologin.aspx , it show error like this
    https://1drv.ms/u/s!Ah3lJWvSyxVOgvcBOsJJntEUNlbZHw
    so, how can i solve this. please suggest.
    #5729
    You should restore the existing Web.config.
    Try this update of Auto Login Plugin. It requires Webstation 5.0.8.0 or higher
    #5730
    What version of Webstation do you use?
    #5732
    scadarapid
    Hi.
    I use Webstation 5.0.7.0
    Now, It works. I did not change the Web.config, I use the Web.config of RapidScada.
    I have to clear chrome cache. then I open the chrome and use “http://localhost/Scada/AutoLogin.aspx”
    Thank you so much.
