Forum Home › Forums › Understanding the Software › If and then implementation
- This topic has 20 replies, 2 voices, and was last updated 3 years, 8 months ago by
September 24, 2022 at 3:50 pm #10904
victorlamParticipantMay I know how can the if condition can be implemented for the input channel?
Let’s say if channel 102 is having value of 100, then for example an event is triggered.September 26, 2022 at 11:12 am #10928
MikhailModeratorYou can use limits for a channel, for example. Or trigger events on every channel data change.
September 26, 2022 at 11:21 am #10931
victorlamParticipantCan I confirm if I need to apply lower limit or lower alarm limits or higher limit or higher alarm limits? Then click event on change checkbox.
September 27, 2022 at 11:40 am #10946
MikhailModeratorWhy don’t you try?
September 27, 2022 at 4:38 pm #10948
victorlamParticipantHello Mikhail,
Thanks for your reply. Actually, I tested and worked.
Together with notification plug in, there is a short beep for the status changed from 0 to 1 or 1 to 0 or 0 to 2 etc.
But I would to have a long beep with the acknowledgement? How can this be implemented? or there is no way to have long beep here?September 27, 2022 at 4:42 pm #10949
victorlamParticipantIf there is long beep implemented, event log showed the “checked” checkbox is ticked.
I do not understand why sometimes this acknowledgement not working sometimes. Or my steps are not correct.September 28, 2022 at 1:58 am #10950
victorlamParticipantPlease find the event log with checkbox unticked
https://drive.google.com/file/d/1MH-PVDyrgOp3MrOOFUHaVe9XCk93XYaz/view?usp=sharing
There is no acknowledgement here. Not understand what is missing here at Administrator in the input channel.
September 28, 2022 at 12:31 pm #10956
MikhailModeratorBut I would to have a long beep with the acknowledgement?
Long beep is possible with Notification Plugin.
“Checked” column in this screenshot means acknowledgement made by operator.
September 28, 2022 at 4:09 pm #10961
victorlamParticipantActually I have already installed the notification plug in. But I cannot receive any continuous long beep sound. Please advise if I have something missing for the steps within Administrator.
September 29, 2022 at 1:17 pm #10962
MikhailModeratorSeptember 29, 2022 at 2:08 pm #10966
Thanks for your support.
I have this notification before provided that the I have set the limit, eg lower limit, lower alarm, high limit, high alarm limit. Yes, I will have the notification under this condition. But I would like to have the notification (long beep with acknowledgement) if the register eg 30001 is having the value of 1 or 2. How can I achieve this notification support?September 29, 2022 at 2:11 pm #10967
victorlamParticipantPreviously I try to set the high limit eg 0.1 and it works but this might not be a reasonable way to design the logic here.
My request is:-
Register 30001 = 1 Alert with notification (with acknowledgement)
Register 30001 = 2 Alert with notification (with acknowledgement)30001 = 1 water leakage condition
30001 = 2 cable break condition
30001 = 3 leakage and cable break togetherPlease help to advise the proposal on this.
September 30, 2022 at 2:17 pm #10969
Please provide a screenshot of Notification plugin that contains visible notifications.September 30, 2022 at 2:37 pm #10971
victorlamParticipantHello,
Please find the snapshot as below:-
https://drive.google.com/file/d/1Uwi3rwV6ZPADMdD0zueoYgJFQXaZFT7E/view?usp=sharing
September 30, 2022 at 2:46 pm #10972
Please find the project file for review as below:-
https://drive.google.com/file/d/1QUKg9sjP_IUykz3e4UaWfr2ZPXaceW-z/view?usp=sharing
Actually, if I set with limits, the notification alarm works fine without issue.
Except the limit, the notification cannot be initiated with the acknowledgement and continuous long beep alarm. -
