Forum Home › Forums › Understanding the Software › Events trigger and colors
- This topic has 20 replies, 3 voices, and was last updated 6 years, 10 months ago by
October 22, 2018 at 7:37 pm #4463
ngiussaniParticipantHi,
I have encounter an issue when trying to custom some events. For instance, if I’m recording an event of an emergency stop, ON should be the “alarm” condition, wich is usually associated with red color, instead of green, as it is shown on the events table. Is there some way to change that for a particular event?
Also, is there a way of recording only one condition of the event?
Thanks in advanced.
October 23, 2018 at 2:39 pm #4470
Event color depends on status color of the input channel. I mean you should change colors of Off-On values.
Create your own record in the Units table, for example,
Normal; Alarm; –
And use formulas for setting the status of the input channel:
Cnl; Cnl > 0 ? 114 : 13October 23, 2018 at 2:40 pm #4471
MikhailModeratorAlso, is there a way of recording only one condition of the event?
Currently no. Some modifications should be done to implement it.
October 23, 2018 at 6:38 pm #4479
ngiussaniParticipantMikhail,
Once again, thank you. Very clear and simple explanations.
October 23, 2018 at 7:05 pm #4480
ngiussaniParticipantI’m sorry to bother you again, but it doesn’t seem to be working with Discrete type (On-Off) and I can’t change the type, as it is a DI in MODBUS. The only way I can think is to make a calculated signal. Is that the only soultion?
P.S.: I was refering to this table view:
This reply was modified 7 years, 11 months ago by
ngiussani.
October 24, 2018 at 12:42 pm #4485
MikhailModeratorPlease provide a screenshot of your configuration related to this issue.
October 24, 2018 at 12:46 pm #4486
Once again, thank you. I was making something wrong with the formulas. The working formula is:
Cnl; (Cnl == 1.0) ? SetStat(1026, 15) : SetStat(1026, 11)
Still, colors in the events table (the one located below the view, with date and time) are shown like the screenshot above: red for OFF, green for ON, wich is the opposite of what I need for the Emergency Stop case.
ngiussani.
October 25, 2018 at 6:25 pm #4497
MikhailModeratorSee my previous message.
October 25, 2018 at 6:34 pm #4500
ngiussaniParticipantHi Mikhail,
I’m not sure what’s the screenshot you’re asking for. What configuration are you refering to?
October 26, 2018 at 2:47 pm #4504
MikhailModeratorInput channels, units that are related to the issue.
October 26, 2018 at 3:51 pm #4507
ngiussaniParticipantOK. I’m sorry I wasn’t clear. I solved that issue. Even thou, here’s the screenshot:
I’m still struggling with colors on the Events table. I don’t know if there is anything I can do at all or if it’s an implementation matter, and is that way.
Thanks again.
October 28, 2018 at 7:52 am #4509
MikhailModeratorThank you for the images.
You need to open the Units table in Administrator. And create a new row with a new unit. Do at as written above. Then set the new unit for your input channel.October 29, 2018 at 12:34 pm #4512
I’m sorry. I missread your answer. I don’t know why I thought I had to change events, instead of units.
That’s working like a charm.
Thanks again!
October 29, 2018 at 4:39 pm #4513
MikhailModeratorCool!
May I ask you about the forum, do you receive notifications when I answer in the topic? Do they work well?
October 29, 2018 at 4:48 pm #4515
Yes. I do receive notifications. Sometimes I just need to remind to tick the box, which I haven’t did somteimes before, but the work well.
